Thread started 26 Oct 2006 (Thursday) 03:51
Fit ANY lens onto a Canon TC?
mxwphoto
Oct 26, 2006 03:51 |  #1
Hi. I read about how the whole front element protrudes on the Canon TC and I was wondering if that can be solved by adding a small tube to compensate for, allowing for any lens to be mounted. Also, I keep reading about tubes for greater macro magnification on a TC, but would TC+tube allow focusing on far objects like the moon??? Thanks!
Great shots are like great parking spaces... if you're not quick, it's gone!
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Oct 26, 2006 04:06 |  #2
No....once you add an extension tube you lose infinity focus.
mxwphoto
Oct 26, 2006 04:38 |  #3
Woolburr wrote in post #2170859 (external link)
Thanks. So something like the moon is out of the question. But how far can you focus to with a small (12mm) tube attached?
PaulB
Joined Apr 2003
Oct 26, 2006 05:39 |  #4
mxwphoto wrote in post #2170902 (external link)
Depends upon the lens focal length.
Acc
Oct 26, 2006 05:58 |  #5
PaulB wrote in post #2171008 (external link)
Ya, and it is usually less than a couple of metres.
Alb
________________
Canon 50D + Canon 450D | 17-40 f4 70-200 f4 L | EF 50 f1.8 II | EF-S 60 f2.8 Macro | Tamron 10-24 f3.5-4.5 90 f2.8 Macro | Sigma 150-500 APO OS |
http://orquideasdeport​ugal.blogspot.com/ (external link)
(words in Portuguese - sorry - but photos in English...) :rolleyes:
Jman13
Oct 26, 2006 06:00 |  #6
If you want to use a TC with other lenses, buy the Kenko 300 Pro TC. Excellent quality and it fits nearly every lens. It works very well with my 80-200L, which has a flush rear element and can't take the Canon TCs.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Oct 26, 2006 11:42 |  #7
mxwphoto wrote in post #2170839 (external link)
Yes I do this sometimes with the 100mm f2.8 macro and the EF 2X using a 12mm tube.
You loose infinity focus but other than that it works well.
The only trick is to note the camera does not show the corrected fstop so you need to remeber the fstop is one or two stops slower than displayed.
So using the 2X with the f2.8 macro I would not go below a set f8 as this is an effective f16 and I would get serious diffration softening.
Macrophotography by LordV
Billginthekeys
Billy the kid
Joined Nov 2005
Oct 26, 2006 11:48 |  #8
when you put the tube on you will loose infinity focus, so its only good for close focusing. you could just get a third party TC though.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
Wilt
Oct 26, 2006 12:05 |  #9
I think the OP is talking about putting the extension tube BETWEEN the TC and the lens! And I don't think that will work! It is breaking the optical (geometric) relationship between the lens and the TC by doing that. So, I don't think it merely shortens the focus distance, I don't think it will work!
I'm not near my equipment to try it out, unfortunately.
Jon
Joined Jun 2004
Oct 26, 2006 12:38 |  #10
It'll work, but cost you infinity focus, as several have noted. In fact that's the recommended order to mount tubes and TC for maximum effect. It's really no different from focussing the lens closer while on the TC.
Jon
Cocker Spaniels
mxwphoto
Oct 27, 2006 01:16 |  #11
Thanks for the input guys. So it seems that it is possible at the cost of inf focus and the method is used mostly for macro. Guess there's no such thing as a perfect alternative to a real longer lens. :)
Woolburr
Gallery: 115 photos
Oct 27, 2006 03:18 |  #12
mxwphoto wrote in post #2175764 (external link)
No, you summed it up your self...there is no substitute for the real thing.:D
Jman13
Oct 27, 2006 05:48 |  #13
MXWPhoto - just buy a non-Canon TC, and you'll get the length plus infinity focus. The top notch third party TCs are nearly indistinguishable from the Canon version, so you're not going to lose image quality.
This is the Kenko Pro (external link)
And this is the Tamron SP (external link).
Both of the above are the same TC (Just with different branding and color), and they are excellent.
mxwphoto
Oct 27, 2006 14:38 |  #14
Jman13 wrote in post #2176384 (external link)
Kenko and Tamron = same company? I never knew that. It certainly wouldn't be apparent from price either. Kenko's $194 and Tamron's $179...
1,432 views & 0 likes for this thread, 9 members have posted to it.
2749 guests, 153 members online
