Thread started 26 Oct 2006 (Thursday) 07:13
Lens Focusing Problem?
erbson
Oct 26, 2006 07:13 |  #1
I have the 24-70 2.8L and I have been using it on a tripod, ISO 100, for senior portraits. I shoot in raw and have even started shooting in raw+jpeg to debug my soft focus problem. I don't think the shots are in focus. I always set the focus dot to the eyes but the whole shot is blurry. I have read on here about calibrating a lens. How, exactly, do I figure out it my problem is the camera, camera vibration from the mirror, lens focusing problem or what? This was an expensive lens and I had hopes of razor sharp photos but mine are never like that. I set up the sheet of calibrated paper and I am still not sure. If I would post a photo would someone be able to interpret all this for me? LJE
Erbes Productions
Canon 20D l Canon EF 24-70mm F/2.8L USM l [COLOR=red]Canon EF 70-200 F/2.8L USM l Canon EF 50mm F/1.8 [COLOR=silver]l Canon EF-S 10-22mm l Canon EF-S 18-55mm l [COLOR=#000000]Canon[COLOR=#000000] EF 28-90mm [COLOR=#ff0000]l Canon ST-E2 l Canon 580EX l Canon 420EX [COLOR=silver]l [COLOR=#000000]Canon I9900 printer l [COLOR=#000000]Sekonic L-358 l Gitzo Studex XL MK2 Monopod l Stroboframe Flip Flash Bracket l Lowepro Mini Trekker AW Backpack l (2) AlienBee 800's l umbrellas
BaliHai
Oct 26, 2006 07:46 |  #2
Noticed recently I was having same problem with 20D after I compared the images from it to the 5D using same lenses on both as well as same studio conditions. Talked to Canon and they suggested I send camera in to be checked (it was still under warrenty). Got 20D back 7 days later and it appears to be corrected, handheld 70/200L f2.8 and shot was sharp. They adjusted focus and exposure as well as cleaned sensor. They said if problem continues send in the lenses, it was a lot easier being without the camera as it would be to be without camera and lenses.
Canon 5D and 20D, 70-200mm f2.8L, 24-70mm f2.8L,
35-80mm, 70-210mm, 18-55mm, 85mm f/1.8, 135mm f/2L
lightmeter, tripod, studio lights
Juan ­ Zas
Oct 26, 2006 13:16 as a reply to  @ BaliHai's post |  #3
One of the best ways to know if you have a focus problem with your lens/camera is using a focus chart as target and evaluate the results.
HERE (external link) you have the one I use & explanations.
Another test focus chart (external link), from Noink D70 but you can use it.
You have more lenses, so you can easily compare and know if it´s only with your 24-70 or with more lenses (then your 20D could be not correctly calibrated)
BTW: There are lastly several threads about this lens with focusing problems. Do the test at several f/stop mostly wide open, different focal distances and also at different distances from the focus test target. (looking for inconsistences)
Good luck
Cheers
Juan
My Photo Gallery (external link)
635 views & 0 likes for this thread, 3 members have posted to it.
2760 guests, 152 members online
