If someone could direct me to the right lens cap, I would be very grateful. I need to order one for my friend but am not sure which one to get. He's got the kit lens, 18-55. Is that a 52mm? 58mm?
Oct 27, 2006 16:29 | #1 If someone could direct me to the right lens cap, I would be very grateful. I need to order one for my friend but am not sure which one to get. He's got the kit lens, 18-55. Is that a 52mm? 58mm?
overclock Goldmember 1,191 posts Joined Jan 2005 Location: Fort Worth, TX More info | Oct 27, 2006 16:32 | #2 the kit lens uses a 58mm lens cap.
It tells the lens size on the front of the lens if you forget. 7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 28, 2006 05:24 | #5 Eagle wrote in post #2179984 It tells the lens size on the front of the lens if you forget. The filter thread size (not the "lens size") is shown on the front ring (around the lens element) of most lenses. You will usually see it as: Φ77mm for a 77mm filter thread diameter, for example. Lens caps are generally sized for the filter thread diameter. Skip Douglas
Oct 28, 2006 14:52 | #6 SkipD wrote in post #2180946 The filter thread size (not the "lens size") is shown on the front ring (around the lens element) of most lenses. You will usually see it as: Φ77mm for a 77mm filter thread diameter, for example. Lens caps are generally sized for the filter thread diameter.
| Latest registered member was a spammer, and banned as such! 2701 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
