Thread started 29 Oct 2006 (Sunday) 13:41
ETTL II or M
MikeKS
Oct 29, 2006 13:41 |  #1
I was wondering how everyone uses their external flash. I personally use ETTL - II and for the most part satisfied with the results. However, i read that some ppl perfer M mode on the flash cause they get better exposures. I have never really used my external flash in M mode cause i usually don't know how to meter for it. So what do you guys do and if you use M how do you meter for it.
-Mike
PS. oh i've also read ppl saying that they find ETTL inconsitant, your thoughts?
5D | 24 1.4L II | Sigma-lux 50 1.4 | Canon 85 1.8 | 70-200 f4L | 430EX | 580EXII
MichaelSimonitsch.com (external link)
Blog (external link)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Oct 29, 2006 13:47 |  #2
The only time I've heard of anyone setting their flash to Manual is if it is a non E-TTL flash. However, setting the CAMERA to manual is the way to go when flash is the main source of illumination. In this case E-TTL II is still being used (for exposing the subject), it's just that you manually set the camera up to get the ambient exposure that you want.
Bob
MikeKS
Oct 29, 2006 13:57 as a reply to  @ Bob_A's post |  #3
Sorry Bob lemme clarify by "M" i meant manual mode of the flash not the camera itself.
PacAce
Joined Feb 2003
Oct 29, 2006 15:26 |  #4
MikeKS wrote in post #2186140 (external link)
-Mike
If you can estimate distances, you won't need to meter the flash in manual mode. Perhaps you'll be interested in reading the following thread if you haven't seen it already. It explains how to use your flash in manual mode.
http://www.photography​-on-the.net/forum/showthre​ad.php?t=146153
But personally, unless I'm in a controlled environment, I usually never use the flash in manual mode, only in ETTL mode.
...Leo
steve547
Oct 29, 2006 16:21 |  #5
Sometimes ETTL can be fooled by bright or reflective objects. So if you're not happy with the exposure you just took with ETTL, you can go to Manual flash and divide you're distance into the guide # for the fstop. But you have to know your guide # for each manual flash setting and for each lens you're using. (These crazy Canon flashes change guide #'s with focal length of lenses).
Steve
_____
EOS 20D, EOS 5D MARK III,18-55mm kit lens, Canon 35mm/f2, Canon EF 24-105 f/4L IS USM, Canon 220EX, Sigma EF-500 DG ST, G2, Canon i960 photoprinter, Canon Pixma Pro 9000 printer, Tamron 17-50 f2.8 non vc.
PacAce
Joined Feb 2003
Oct 29, 2006 17:16 |  #6
steve547 wrote in post #2186808 (external link)
I think you can also benefit from my previous post re working with the EX flashes in manual mode. ;)
...Leo
Curtis ­ N
Master Flasher
Oct 29, 2006 17:57 |  #7
We should set a few things straight here.
1) The guide number of any flash with a zooming head will change as the zoom seting changes. Whether it zooms automatically or manually, it's a matter of physics, not a crazy design element of Canon flashes in particular. It's related to lens focal length only as far as the flash zooms to match the focal length.
2) Your ISO setting will also change the guide number. At ISO 200 you need to multiply it by 1.4. At ISO 400 you need to double it.
3) You can memorize every guide number, at every zoom setting and every ISO, and calculate the distance at various apertures in your head, or you can just read the distance scale on the back of the flash unit. The flash does all the calculations for you!
MikeKS
Oct 29, 2006 18:37 as a reply to  @ Curtis N's post |  #8
Thanks guys! Looks like i got some reading/playing with my flash to do
steve547
Oct 30, 2006 21:12 |  #9
That may be another advantage of the 580EX over my Sigma 500DG ST. I don't have any scales on the back of the flash, and the flash zoom is completely automatic. So I cant just manually choose the zoom position of my widest lens and memorize that Guide #. As far as ASA, I could use ASA100 and still shoot at 20 feet with f8. That covers most of my flash needs.
Steve
_____
1,380 views & 0 likes for this thread, 5 members have posted to it.
ETTL II or M
1317 guests, 124 members online
