Thread started 30 Oct 2006 (Monday) 00:10
Do I really need the 70-200 F4
MDoc
Oct 30, 2006 00:10 |  #1
I have the lens kit, 50MM1.8, 24-105L IS and 100-400L IS. Should I sell my 70-200F4 and look for a better wide zoom? Anyone have these lens and find that you still use the 70-200F4 much at all?
Ray : "My pictures are only worth 100 words"
A01
Oct 30, 2006 02:56 |  #2
If i was you id sell the lens and go for a 10-22mm
Aaron
FOR SALE
- My Gear - Some of my Work (external link) - POTN Aussie Club -
Pixel9ine
Oct 30, 2006 03:03 as a reply to  @ A01's post |  #3
Same as above; you've got just about the same F.L. coverage with the 100-400 at a nominally smaller aperture. The only reason I'd keep the 70-200 F4, if I were you, would be the portability/weight advantage. (As it stands, I absolutely love mine -but then again it's my longest lens)
Sell the 70-200 F4, dump the kit lens while you're at it and get an EF-S 10-22 or Sigma 10-20. You'll be all set.. they're two of the finest UWA zooms available.
Andre B :: gearlist
www.pixel9ineexternal link.com
saravrose
"I quit smoking dope"
Oct 30, 2006 07:52 |  #4
it seems that you have yourself covered with the 100-400... so unless you like using it as a comfortable walk-around lens probably not...
sari
Canon 30D BG_E2 Grip Rebel XT BG-E3 battery grip
Canon 50mm f1.8 Tamron 17-50 f2.8
Canon 70-200f4.0L 100-400L aka (Chuck)
a couple of bags and a lot of big ideas
"The shot is in my head before it's in front of my camera...."
BearLeeAlive
All butt cheeks and string.
Oct 30, 2006 09:34 |  #5
I could not see myself getting rid of the 70-200 f4 even once I do get the 24-105 f4 as it is my choice for hiking as the 100-400 is a bit heavier and bulkier.
Even though it hardly ever gets used, the 10-22 is indispensible for those times when you do need it, especially seeing you only go down to 24mm with your current kit. Even with 17 covered I somtimes find the need to go wider.
-JIM-
MDoc
Oct 30, 2006 12:08 |  #6
Thank you all for your help. I was thinking of the ef-s 10-22 I need to go to the shop and try one out to see if I like it.
JNunn
Oct 30, 2006 12:50 |  #7
MDoc wrote in post #2190709 (external link)
I would DEFINITELY do this. I tried the 10-22 before I bought my 17-40L and just didn't like it enough to choose it over the 17-40L. Many people on this site love the 10-22 and don't consider anything else to be wide enough. I agree, that for interiors, the 10-22 is a good choice, but I needed more of a walkaround and the 10-22 is too short for that. Also I like landscapes and at 10mm the subject is so small that I was concerned that I wouldn't get the detail that I like.
And for what its worth, I've got the 70-200L and the 100-400L too. Each has its uses, but the size and weight of the 100-400L limit its use IMO to those times when you need the extra reach. The 70-200 f/4 is much easier to carry and use. (Though I might upgrade to the IS version once the price calms down a bit!)
steved110
Oct 30, 2006 15:20 as a reply to  @ JNunn's post |  #8
The 70-200 f/4 is a lovely lens, sharp as a tack, super quick to focus, truly a wonderful optic, and best of all is light enough to carry around all day and use unsupported. It's also a fantastic lens for candids and outdoor portraits, indoor is OK too with a little room and preferably a flash.
the 100-400 is a fair bit heavier, has that pump zoom thingy ( remember when all zooms were like that? ) and while it has IS, it's still a big heavy lens.
The only way I'd sell my 70-200 f/4 is if I suddenly got rich and got the IS version. the 100-400 really is meant for different purposes, and unless you simply NEVER use the 70-200 f/4 then there is no reason not to keep both.
Regarding choosing between the 10-22 and the 17-40, when I was in this situation, I decided that for only a little bit more cash I'd get far more use out of the 17-40. and being an L lens, once I had it in my hands, the quality jump from consumer lenses was staggering. I was smitten, and I still am. I use the 17-40 as my walk about, it's on the camera 95% of the time. I felt that the 10-22 was simply too wode for every day use as a walk about.
To be honest if I was in the market for an ultra wide, i'd take the sigma over the Canon any day - so much better value, and I already have that 20-22mm range covered nicely. ;)
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
914 views & 0 likes for this thread, 7 members have posted to it.
2715 guests, 144 members online
