Thread started 30 Oct 2006 (Monday) 02:51
Big Smile from Brynn
YosemiteJunkie
Oct 30, 2006 02:51 |  #1
Little by little I think I've getting a touch better at the "on the fly" portraits and a little better at PS but still not the quality that I repeatedly see here. Can you tell me what I might have done to make this better?
http://photography.dun​nnet.com …displayimage.ph​p?pos=-280 (external link)
I hit it lightly with curves and brightened the smile and t-shirt a bit with levels and cloned out a couple of small blemishes. Flash was used to fill in but I think it might have been better if I had bounced it off the ceiling. Please give me your C&C. Thanks in advance.
Happy Shooting, Herb
Canon 5D, 20D w/ BG-E2 Grip, Rebel 35mm, 580EX II Flash, 420EX Flash, Canon EF 50mm f/1.8 II, Canon EF 17-40 f/4.0 L, Canon EF 24-105 IS L, Canon EF 28-135 IS, Canon EF 70-200 f/4.0 L, Sigma 150-500 EX DG, Manfrotto 055XProB Tripod, P.O.T.N. Pro Strap (black)http://HerbDunn.com (external link)
Curtis ­ N
Master Flasher
Oct 30, 2006 07:26 |  #2
At 1/250, f/6.3, ISO 200, the flash was more than "fill in". It was the main light source. I agree that ceiling bounce probably would have produced better lighting.
Is her skin really that red? If not, you might want to adjust the color temp a bit.
She did give you a nice expression!
YosemiteJunkie
Nov 01, 2006 02:07 |  #3
Thanks so much for the feedback, Curtis.
here is a remake of that same photo with the skin tones just the way they came out of the camera. Only brightened her teeth and tshirt and removed a couple small blemishes. Please let me know if you think his is any better or worse. I think it's a bit better myself but I'm still learning. Thanks again.
http://Photography.Dun​nNet.com …displayimage.ph​p?pos=-281 (external link)
Edit: Below is my try at the B&W
http://Photography.Dun​nNet.com …displayimage.ph​p?pos=-283 (external link)
D. ­ Craig ­ Flory
Nov 01, 2006 08:22 as a reply to  @ YosemiteJunkie's post |  #4
I am posting my version ... in black and white. The contrast & color balance were such as to make it tough to work in color. So here is my B&W version.
D. Craig Flory PPA Certified, Cr.Photog.,
ASP // loryphotog@mindspring.​com (external link)
Curtis ­ N
Master Flasher
Nov 01, 2006 09:00 |  #5
Herb,
I think the second link you posted looks better, at least on my monitor. If the first one doesn't look "too red" to you, it may be time to calibrate your monitor.
98photo
Nov 01, 2006 09:03 |  #6
Great expression, I like it better in b&w though.
YosemiteJunkie
Nov 02, 2006 01:26 |  #7
D. Craig Flory wrote in post #2200216 (external link)
Thanks D. I got to admit it does look pretty good in B&W. Did you just desaturate it or were other steps taken. If other steps, could you explain how. Every time I try converting a shot to B&W I'm not really happy with the results.
Thanks again.
YosemiteJunkie
Nov 02, 2006 01:31 |  #8
Curtis N wrote in post #2200325 (external link)
Herb,
It does look a bit over red (my first post). I was trying to get some "POP" in it and guess I over did it. Some day I might get the quality I keep seeing posted here but for now I'll just keep dreaming and learning from those of you that know better than I. Thanks again.
D. ­ Craig ­ Flory
Nov 02, 2006 07:08 |  #9
Hi Yosemite;
I just used my black and white action I wrote. It is a two part action that uses channels and then adds a bit of contrast. I then did my creative crop and made it into a step-mount for impact. (in order to crop it like that I made a new canvas in a long skinny size. I dragged it onto the image and used Edit > Rotate till it was at an angle I liked. I then duped it and turned off the eyeball for one of them. I clicked Select > Load Selection. Next I clicked on the image layer and clicked delete on the keyboard. I then deleted the skinny layer I added ... and saw a transparent area where it sat. I then used the eraser tool to erase any area outside of where I deleted. Now I turned back on the eyeball for the other skinny layer and moved it to the other corner and repeated the steps. I hope I remembered my steps and wrote them so you can understand. Hope this helps everyone.
YosemiteJunkie wrote in post #2204088 (external link)
Thanks again.
1,350 views & 0 likes for this thread, 4 members have posted to it.
2816 guests, 139 members online
