Thread started 30 Oct 2006 (Monday) 06:27
Your Opinion on Canon EF 24mm f/2.8
AiGTs
Oct 30, 2006 06:27 |  #1
What do you think this lens: Canon EF 24mm f/2.8. Thanks!
20D 24 2.8 85 1.8
M8 35Lux 50Lux 50Nok
dputz
Oct 30, 2006 06:38 |  #2
It's a quick and dirty f/2.8 lens, is fairly sharp, but the focus is slow due to it's lack of USM.
--Dan Putz - The Slate (external link)
dputz Photo Equipment Roster
...going broke for the sake of art...
--==SALE PENDING: 300 f4==--
chtgrubbs
Joined Jul 2003
Oct 30, 2006 10:58 |  #3
I don't use mine for action, so lack of USM focus is no problem. Mine is satisfactorily sharp all the way into the corners when stopped down to f/5.6. It seems to equal or better my 24-105L with much less curvilinear distortion.
dputz
Oct 30, 2006 11:01 as a reply to  @ chtgrubbs's post |  #4
(I'm selling mine btw...but that isn't for here)
Double ­ Negative
*sniffles*
Oct 30, 2006 12:12 |  #5
Unless you need the focal length, the 35mm f/2.0 might be a better choice. Not quite as wide, but brighter and sharper.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
AeroSmith
Gallery: 46 photos
Joined Feb 2006
Oct 30, 2006 12:17 as a reply to  @ Double Negative's post |  #6
How about the EF 28 f/1.8? It's not quite as wide but it has USM and it's a stop and a third faster.
Josh Smith
timmyb
Oct 30, 2006 13:26 as a reply to  @ dputz's post |  #7
Nice little lens.Very useful 35ish FOV on a cropped body.I don't use it very often but when I do it's always capable of producing something a bit special, even if I'm not.
AiGTs
Oct 30, 2006 15:04 as a reply to  @ timmyb's post |  #8
Thanks for the help guys. I've read a lot about the 24mm f/2.8, 28mm f/1.8, and 35mm f/2. The 24mm has the best review out of the 3, but it's older and AF is loud/slow. From the reviews online, the 28mm and 35mm have some image quality issues and I don't know if I would happy with them if I had them. I use my 50mm f/1.8 all the time and love the result it gives me, so I'm looking to get a wider prime which will allow me to shoot closer with the same image quality the 50mm could give me. What do you think I should do? Thanks again!
20D 24 2.8 85 1.8
pyrocars
Oct 30, 2006 15:27 as a reply to  @ AiGTs's post |  #9
I bought one for car show stuff. Here are some I took at a couple shows. The only thing done to them was resize for web and a very small sharpen from the resize.
http://www.picturetrai​l.com/pyrocars (external link)
Here is one I liked
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by PICTURETRAIL
http://www.flickr.com/​photos/pyrocars/ (external link)http://www.pyrocars.co​m (external link)
Double ­ Negative
*sniffles*
Oct 30, 2006 15:27 |  #10
AiGTs wrote in post #2191541 (external link)
Huh?
What IQ issues are there with the 35mm f/2.0? It's sharper than the other two lenses.
steved110
Oct 30, 2006 15:33 as a reply to  @ AiGTs's post |  #11
Have a look at The Digital Picture (external link) for general reviews of all the Canon lenses.
IMO the 24mm lens is not really of much use on a crop body - it isn't very wide at all. so personally I'd go for the 28mm f/1.8 which has USM and FTM and is faster too.
The 20mm f/2.8 USM lens gets better reviews, is wider, and IMO more useful - it gives a 32mm equivalent FOV on a 1.6 crop which is pretty wide. And it's build quality is much better, and the lens has USM too. However it does vignette ( this will be less noticeable on a crop factor camera) and has some innate softness which is disappointing for a prime.
The reviewer at the digital picture actually felt it would be better to ave a bit more and get the 17-40L or preferably the 16-35L - but then he always does push for L lenses.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
AiGTs
Oct 30, 2006 23:05 |  #12
Double Negative wrote in post #2191686 (external link)
Huh?
From the reviews online, the 28mm f/1.8 has chromatic aberrations issues, and 35mm f/2 has high vignetting and softness at larger aperture setting. I like to shoot at a relatively large aperture indoor, so if those lenses will give me soft and vignetting results I will be disappointed. This is why I'm asking for opinions on the lenses before I drop the money. Any input will be greatly appreciated. Thanks!
20D 24 2.8 85 1.8
Double ­ Negative
*sniffles*
Oct 31, 2006 09:25 |  #13
AiGTs wrote in post #2193625 (external link)
Reasonable enough... I don't recall any such problems with my 35mm f/2.0, it has always given me great shots. I used it mostly on a 1.6x crop camera (D30) and not so much on 1.3x. Don't know how it reacts to full frame.
http://litpixel.com/ee​/photo.php?photo=274 (external link)
http://litpixel.com/ee​/photo.php?photo=572 (external link)
chtgrubbs
Joined Jul 2003
Nov 01, 2006 11:28 |  #14
At wider apertures my 35/2.0 will definitely outperform my 24/2.8 in terms of sharpness (especially in the corners) and falloff, and this is on a full frame camera. On a smaller sensor you should have no problem at all.
AiGTs
Nov 02, 2006 03:40 as a reply to  @ chtgrubbs's post |  #15
Double Negative: Those shots are beautiful. I have a 50mm f/1.8 that I use all the time. Do you think it's worth buying the 24, 28, or 35, or should I just spend a little more and buy a wide angle lens.
chtgrubbs: Thanks for the input. I have a 20D so the crop factor should take care of the corner softness at its widest apertures. If you have used the 50mm f/1.8, do you think the 24mm f/2.8 lens will give me the same image quality as the 50mm would?
Thanks guys.
20D 24 2.8 85 1.8
2,464 views & 0 likes for this thread, 10 members have posted to it.
2809 guests, 134 members online
