Thread started 30 Oct 2006 (Monday) 07:48
What happens to returned "L" lenses? Open box?
Hockeyphoto
Oct 30, 2006 07:48 |  #1
I'm buying a new 24-105 L IS lens this week from one of the major online camera shops (IE Beach Camera, B&H photo, Abes, etc.) and was wondering how you can tell if the box has been opened and if the lens is a return or not? I know there are no seals on the box, so how can I be sure this isn't a bad return lens that's been carefully packed back up and sent out to me?
What do they usually do with returns like this? I know with the rebates that lens sales are higher right now, so the possibility of them re-selling a lens as opposed to returning it to Canon because of low inventory may be a possibility, but is this just me being paranoid about buying an expensive "L" Lens and being stuck with a lemon. Don't get me wrong, I plan on testing the lens out, but I'm just an amatuer and can't be 100% sure I'm checking everything correctly. I just want a NIB lens like I paid for.
Any comments or feedback is appreciated!! I plan on testing my lens in Sedona AZ a few days after I get it, so the oppurtunity will be there to give it a workout....
Canon 5D Mark III, 7D, G12, Canon 5D Mark IV on Pre-order
Canon 70-200mm F/2.8 L IS / Canon 24-70mm F/2.8 L II / Canon 85mm F1.2L II / Canon 100mm F2.8L IS MACRO / Canon 24-105mm f/4.0 L IS
Canon EF-S 17-55mm f/2.8 IS USM, Canon EF-S 10-22mm
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Oct 30, 2006 08:26 |  #2
In my expereince of three new recent lenses, boxes aren't sealed and the plastic bag that the lens is in is not taped, so they don't even make an effort to seal the lens.
This might well be deliberate because I suspect quite a few lenses are exchanged and they would want to resell those rahter than have them returned to Canon.
Photos from my travels (external link)
Canon EOS R6 MkII | Canon EF 24-70mm f/4L | Canon RF 100-500mm f/4.5-7.1L | Samyang 14mm f/2.8
ssitu
Oct 30, 2006 09:19 |  #3
I bought many gears from Canada and US, none of them had any seal on the box or tape on the plastic bag :( I believe Canon does not put any seal on the boxes, so I guess there is no way to know if it has been opened or not.
40D with grip, 580EX(2), ST-E2
EF 50mm f1.4
EF 24-105mm f4L IS, EF 70-200mm f2.8L IS
Sigma 10-20mm
Double ­ Negative
*sniffles*
Oct 30, 2006 09:27 |  #4
There are no seals from the factory.
Look for obvious signs; the plastic bag is more crinkled than it should be, there's fingerprints all over the lens or dust, the warranty card is folded twice, etc.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Bill ­ Ng
Oct 30, 2006 09:40 as a reply to  @ ssitu's post |  #5
If you are not sure how to test the IQ, or any other factor of a lens, you are throwing your money away on an L. You're better off saving the cash, buy a consumer grade lens and practicing with it for 2 - 4 years. Learn to shoot, learn about trigger control, breathing control, body position, and get overly familiar with your camera.
Play with a slow telephoto and a cheap fast prime ... play with them for two years or more. The slow telephoto will teach you to steady your shots in lower-light conditions. The fast prime will teach you about depth of field. Once you've done all of this ... now look into investing real money in this hobby.
If you want to blow thousands of dollars now to help you get a better picture you are more than welcome to do so. But keep in mind that doing so will teach you to rely on your equipment for a better picture and will keep you from learning the techniques that separate the snap-shooter from the photog. That trend runs rampid around here ... don't fall into it.
My $0.03
Bill
Billy Ng
1 Body
4 Lenses
3 Strobes
Never enough time
EoSD30fReAk
Joined Aug 2003
Oct 30, 2006 10:43 as a reply to  @ Bill Ng's post |  #6
like said before, there's no way to be certain that it's not a return object.
and the seal not being there has a purpose, what if you want to try a lens in a shop before you buy it? than the sales would have to break the seal and when you don't take it he would not be able to sell it as new.
Photography is my way to relax
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Oct 30, 2006 10:58 |  #7
My normal supplier claims all lenses are direct from Canon, possibly true but no way to check if the item is in stock and there is no wait.
Macrophotography by LordV
Panza
Joined Aug 2002
Oct 31, 2006 05:39 |  #8
If you're happy with the lens does it really matter if it works and looks like new ?
If you're not happy with it just return it.
Canon Eos 1D MK4 | Canon Eos 5 | Complete Gear List
Master-9
Oct 31, 2006 08:17 |  #9
Taken from Khalil Gibran's writtings:
And what is fear of need but need itself?
Is not dread of thirst when your well is full, the thirst that is unquenchable?
From Decatur Georgia(USA)
Canon 40D+ BG-E2N, Canon 20D, Canon PowerShot G12, Canon PowerShot G7, Canon Rebel(Film)EF-S 18-55mm f4-5.6, EF 28mm f2.8, EF 50mm f1.8 Mk I, EF 85mm f1.8 USM, EF 24-70 f2.8L USM, EF 70-200mm f4L USM, Canon Speedlite 420 EX
PetKal
Oct 31, 2006 09:00 as a reply to  @ Master-9's post |  #10
In fact, Khalil Gibran wrote words which could be turned into a sticky on this forum:
" Most people who ask for advice from others have already resolved to act as it pleases them."
Potenza-Walore-Prestigio
Scott_Quier
Oct 31, 2006 10:08 as a reply to  @ PetKal's post |  #11
There are a couple of places you can find clues. These box lids are constructed so that it is nearly impossible to open them without creasing the finish on the box and especially on the little tabs on the ends of the last fold on the lid. So, before you open the box, take a close look at all surfaces surrounding both lids (top and bottom). If you see excessive fingerprints, folded cardboard, etc, then you have a clue.
But, like Panza said, "If you're happy with the lens does it really matter if it works and looks like new ?"
Scott
Operation: Love Reunited (external link)
Check out my blog (external link) Gear List
whiskaz
Oct 31, 2006 10:13 |  #12
Scott_Quier wrote in post #2195418 (external link)
Ohhhhh I dunno... because you can buy used for 10-20% less on here, FM, eBay etc?
...but you're right... in the end, happiness is all that really matters (ya bunch of hippies!) ;)
Jeremy | Gear List | EyeDigress - A Photoblog (external link) | blinkphotography.net (external link)
"This aggression will not stand, man."
HughScot
Oct 31, 2006 10:15 |  #13
Bill Ng wrote in post #2190107 (external link)
My $0.03
Bill
The only trouble with this philosophy is you will have spent a great deal more money in the long run. If you are sure you are going to progress to the point of needing an "L" lens or a very fast lens than go ahead and get what you will eventually need.
My 2 cents
Hugh
Hugh
Canon 40D, EF 24-105mm f4L IS, EF 35-135, EF 70-200 f2.8L IS, EF-S 10-22, EF 100mm f2.8 macro, Sigma 18-200 OS.
Baddrummerboyy
Oct 31, 2006 10:20 |  #14
I just bought the sigma 17-70. Came in last night. Order it from B&H photo. I was disappointed in the shipping box they shipped the lens in. It did not have a lot cushion. Looks like the lens could move around a lot. I order a canon 50mm f1.8 from compusa, since I got discounts there. It came in two days, In a really protect covering and a really big box fill with those air cushion everywhere. Yeah you cant tell if it been open or used on either lens I got.
Current: Canon 40D w/BG-E2N, Canon 30D, Canon 10-22mm, Canon 17-55mm 2.8 IS w/EW-83J, Canon 70-200mm 2.8L IS, Canon 580EX II, Crumpler 6 Million Bag, and B+W MRC on all my glass.
steved110
Oct 31, 2006 13:04 as a reply to  @ Baddrummerboyy's post |  #15
If you can't make the basic assumption that your seller is honest - you should be buying from someone else. too much suspicion in this world as it is.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
5,152 views & 0 likes for this thread, 22 members have posted to it.
893 guests, 152 members online
