Thread started 30 Oct 2006 (Monday) 14:23
circular polariser?
philbyuk
Gallery: 52 photos
Joined Nov 2005
Oct 30, 2006 14:23 |  #1
Ok been thinking of getting a circular polariser for my lens(17-40L, and 70-200L) im looking for a 77 mm to fit, and wondered if i need to get a 'thin' type ? as ive heard stories of vignetting on some wide angle lenses, would this affect my 17-40L on a 20D? (or will a 'normal one be ok?)
I called into my local store and they wanted £125.00 for the hoya pro one , can anyone suggest a cheaper 1 (but still need good quality).
Yes i know i need to look around but would appreciate suggetions for other good/reputable makes before i check the prices out
thanks phil
My 365 '2018' (external link)
coreypolis
Oct 30, 2006 14:26 |  #2
it will vignette anyway, and with a thin the lens cap won't work. just get a normal and don't use any other filters with it.
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
philbyuk
Gallery: 52 photos
Joined Nov 2005
Oct 30, 2006 14:41 |  #3
thank corey the lens cap isnt to much of a worry as i would only be using the filter as and when reqd so the filter wont be on it when i put the camera away.any suggestions for other makes?
Jon
Joined Jun 2004
Oct 31, 2006 14:40 |  #4
A normal 77 mm filter shouldn't vignette on the 17-40 on a 20D. If you upgrade to FF, you might have a problem, but for an APS-C camera I think you'll be OK.
Jon
Cocker Spaniels
JNunn
Oct 31, 2006 15:45 |  #5
I use a thin B+W multicoated on my 17-40L. No vignetting and I don't mind the friction-fit cap.
Tony-S
Oct 31, 2006 23:48 |  #6
philbyuk wrote in post #2191294 (external link)
I use Sigma's thin CPL (external link) for my 10-20 and 17-40L. It is threaded so your lens cap will fit on it. I'm quite happy with it and recommend it. It was US$140, which is a bit less?
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
philbyuk
Gallery: 52 photos
Joined Nov 2005
Nov 01, 2006 00:24 |  #7
thank you all for your replies will look at the alternatives
johnstoy
Nov 01, 2006 03:49 |  #8
You've got to consider the other brands Like B + W, Heliopan, and Hoya...
I'm researching to purchase additional 77mm filters, including the Circular Polarized Filter...there really aren't that many choices or brands offering a quality multi coated CP when sorted out...I'm now sorting by price to see what the best one is that I can afford...
Go to the vendor web sites and sort by type, size and price, and compare...You'll be surprised at the few to choose from at your estimated cost of purchase.
John Stoy
www.poconophotos.com (external link)
My Gear List
"Are you only Looking or actually Seeing", from Microbiology 101.
Double ­ Negative
*sniffles*
Nov 01, 2006 11:34 |  #9
Heliopans are all "slim" style now, but maintain front filter threads for use with lens caps. B+W I'm not as familiar with but are also of very high quality otherwise. Next up are typically Hoya Pro1 filters.
Not all "slim" types have front threads. As long as it does then you can still use a cap. I might suggest picking up a "Tamron style" cap, which has extra pinch areas in the middle of the cap, making removal much easier with a hood affixed - and fit better on slim filters since the thread depth is less than the average Canon cap.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
1,664 views & 0 likes for this thread, 7 members have posted to it.
circular polariser?
644 guests, 119 members online
