Thread started 30 Oct 2006 (Monday) 16:26
Smoke from flash, Rebel XT
Gerdav43
Joined Sep 2003
Oct 30, 2006 16:26 |  #1
While taking pictures a while back I noticed a burning smell from the Rebel XT onboard flash. This just happened to be after I received the camera back from a warranty repair. I did not notice the phenomenon again until today. Same burning smell and small whisps of smoke emanating from the top center of the flash, as if there were a little pin hole up there. It did not smolder, just a whisp of smoke and that was it. I will be sending this in (it was under warranty when they fixed it last time.....but not now of course), but has anyone experienced this type of activity? What did you learn about the fix.
Canon 60D
Canon 70-200 F4 L + Sigma 1.4 T-con
Canon 50mm 1.8
Canon Speedlite 580EX/Canon Speedlite 420EX
angryhampster
"Got a thick monopod?"
Oct 30, 2006 16:40 |  #2
It must be an electrical short. Really strange. I take it you were using flash while this happened?
Steve Lexa
Iowa City Wedding Photography (external link)
gjl711
"spouting off stupid things"
Oct 30, 2006 17:28 |  #3
Gerdav43 wrote in post #2192023 (external link)
Boy, that can’t be anything good. I thought that maybe it might e a bug, critter, not software, and I just pulled out my XT and flashed away while I had my finger on the flash. It just does not get hot enough to smoke anything, even after 5 or so flashes. Send it back.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Eagle
Gallery: 62 photos
Oct 30, 2006 17:44 as a reply to  @ gjl711's post |  #4
Doesn't sound like a good thing.
Do a search, I recall seeing a few other threads about this issue with various cameras. Don't remember reading any results though. I would definitely give Canon a call.
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
Gerdav43
Joined Sep 2003
Nov 03, 2006 08:52 as a reply to  @ Eagle's post |  #5
Figured out the problem, sent it in to Canon. Apparently there is an issue with how they put the camera back together when I sent it in in July.
I found that when in auto mode and I half pressed the shutter the meter indicated that the flash was necessary and the flash indicator came on, however, the flash did not go up. Press the shutter and the flash fires in the closed compartment. This burns the plastic on the body, thus causing an unbelievable smell. You can actually see the burn marking on the plastic. It's shaped just like the flash. The whisps of smoke I metioned in the previous post seem to be coming from plastic residue that sticks to the flash and then burns off on following flashes. Fortunately we were able to reproduce the problem at the store. They were very good to me. I said I wanted to document the problem and bring the camera back next week because my son has a soccer tournament and my daughter's Bday is next week (told her I did not need the onboard flash). The owner would not let me walk out of the store with the camera in that condition and gave me a store loaner. Guess she was afraid I might set my hair on fire if the flash did the same thing again. Just thought I'd let everyone know what was going on.
Canon 60D
Canon 50mm 1.8
tzalman
Fatal attraction.
Nov 03, 2006 10:07 |  #6
Wow! There's another good reason for never using Auto.
Elie / אלי
Gerdav43
Joined Sep 2003
Nov 17, 2006 02:03 as a reply to  @ tzalman's post |  #7
Well, I sent the camera back. It returned to the store and they said everything was working fine. Canon replaced the top cover (flash assembly), the PCB motor drive and bottom plate (??). This is after they replaced the main dial, main PCB (printed control board) and top cover on the previous service.
Went to pick up the camera and they said they played with for a while and it appeared to work. I played with the camera in the store and took three pictures. The first were fine. On the third attempt the flash stuck down and was going to flash closed. AHHHHHHHHHH!!!. Took a picture for yuks and what a great plastic burning smell. They loved it at the store and could not believe it was still happening. It was very intermittant but I was able to reproduce the issue numerous times for the store owner. As for the cause of the issue. I still have no answer. I suspect that when they put the camera back together the first time that something was slightly out of line. Not visible to the eye. I found that the issue re-occurred depending on how I pushed the flash down. My guess is that part of the flash would get stuck on the body ever so slightly.
The good news - The owner called her Canon rep with my tale of woe. She had originally said that she was going to send it in again. I told here I was leary because they have essentially replaced all the inner parts of the camera. I would also feel uncomfortable selling the camera to anyone after it comes back knowing its problems. She agreed. Canon authorized a return of the camera and authorized a free replacement with another XT. I of course looked at this as an opportunity to upgrade. For an additional $200 I was able to get the XTI (It was $200 because they are announcing a price drop on the XT soon, I guess its run is about over). I felt it was worth it for the additional screen size for chimping, the added focus points, the sensor cleaning option and another year of warranty. Lets not forget that I got over a year and one half of service from the old camera. My first picture IMG 0001. I'm happy and I have a brand new camera. Thank you Canon.
Canon 60D
Canon 50mm 1.8
Pixel9ine
Nov 17, 2006 02:24 as a reply to  @ Gerdav43's post |  #8
Wow... all's well that ends well. Congrats on the new camera!
Andre B :: gearlist
www.pixel9ineexternal link.com
Lightstream
Yoda
Joined Feb 2006
Nov 17, 2006 03:57 |  #9
Ouch.. that is one awful story. Glad it ended well, though. And since it's an XTi, there's no way EVER it could be that half-baked XT finding its way back to you by some quirk of fate :D
Do I forsee a big external flash in your future? ;)
Double ­ Negative
*sniffles*
Nov 17, 2006 09:36 |  #10
Congrats! Sorry it was such a painful process.
Once the magic smoke escapes the wire, things don't work so good no more. :D
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Gerdav43
Joined Sep 2003
Nov 17, 2006 17:28 as a reply to  @ Double Negative's post |  #11
Do I forsee a big external flash in your future? :wink:
I have two big ones, a 580 and 420. My wife, however, uses the onboard flash for the around the house snapshots. At least now I don't have to worry about her hair catching on fire. :lol: Maybe a P&S is in my lovely bride's future.;)
Canon 60D
Canon 50mm 1.8
justhavingfun
Dec 12, 2006 08:33 |  #12
I am new to CDPF and new at photography, reason for my responce is that my husband bought me a Canon Rebel XT for my birthday 3 months ago and just this week had the same thing happen as you. The place where he bought the camera, basically laughed in my face as I tried to explain what happened, so I have no support from them. Could you go into a little more detail ( if you have it ) on what they might have said, did, anything.
Kraig ­ C
Dec 12, 2006 08:46 |  #13
if someone laughed in my face about a problem I'm having with a product they sold me I'd have to demand a refund or replacement on the spot.
gjl711
Dec 12, 2006 09:06 |  #14
Kraig C wrote in post #2388798 (external link)
Demand, yell, stomp, but in reality there is little you can do once time has passed on the store return policy. This is pretty much true for all places. Though I would never advocate laughing in a customers face as it is never good for business unless you’re running a comedy club, and i would never do business with them again as well as advise all who ask not to do business with them as well, the reality is that after 3 months you’re better off working with Canon directly. All the store will do anyway is sent the product into the service center for you.
::Gear::
Gerdav43
Joined Sep 2003
Dec 12, 2006 09:22 as a reply to  @ gjl711's post |  #15
Basically what happened and what I did is posted throughout this thread so I will not go into more detail. What you should do is not explain the problem, but show them the problem if you are able to re-create the issue. If it happened once I would not be so concerned as to ruin your photography experience. You also have nine months left on your warranty. Certainly if this is an issue with your camera it will occur again during that time.
I found in the basic modes Auto Mode, Portrait mode etc. where the camera called for flash the flash would stick down yet still fire causing the arrid smell. If you can re-create this for the store they should send it back to Canon for Warranty repair. You will generally be responsible for the shipping but there should not be any other fee if it is a reputable store. If they charge you to fix the camera other than a shipping fee (generally around $20.00) you can send it back yourself. Search the Canon Website for support on that issue.
Canon 60D
Canon 50mm 1.8
3,987 views & 0 likes for this thread, 11 members have posted to it.
566 guests, 120 members online
