First go at a waterfall, I had no tripod so had to rest it in a rhododendron bush
![]() | HTTP response: 503 |
C&C Welcome
MAH Senior Member 647 posts Joined Nov 2005 Location: Shropshire, UK More info | Nov 01, 2006 16:14 | #1 First go at a waterfall, I had no tripod so had to rest it in a rhododendron bush
C&C Welcome
Nov 01, 2006 16:26 | #2 Not bad at all for using a treepod http://natureimmortal.blogspot.com
montreal Goldmember 1,194 posts Joined Apr 2005 Location: Trondheim, Norway More info | Nov 01, 2006 18:41 | #3 Not bad at all. As said previously underexposing a bit would have helped. Using a polarizer to remove the glare from the vegetation would have brought out the greens. 5D - 17-40L, 70-200L f4, 50 f1.4, PowerShot A430
Nov 02, 2006 05:08 | #4 Neilyb wrote in post #2202231 Not bad at all for using a treepod ou could easily have underexposed a little and got more detail in the fall, but great first effort with no tripod ![]() Ta
Nov 02, 2006 05:11 | #5 montreal wrote in post #2202833 Not bad at all. As said previously underexposing a bit would have helped. Using a polarizer to remove the glare from the vegetation would have brought out the greens.
AdamJL Goldmember 4,365 posts Likes: 13 Joined May 2006 Location: 'Straya More info | Nov 02, 2006 06:12 | #6 |
Nov 02, 2006 06:58 | #7 MAH wrote in post #2204546 Ta ![]() I've been reading up on this blending 2 images from one exposure... If I haven't lost everything in the water I might use it as practice. Is it best to meter for the water and then under expose or just use evaluative and then try a few shots at -1/3 -2/3 etc. Erm, as you have the 30D you have to be careful how underexposed you go, pulling back detail later can cause more noise. The 5D makes life easier for this and I am spoilt. But the shot above could have been taken further 2/3 under without needing too much PP. Poloriser would help a load too, cutting out the majority of glare. http://natureimmortal.blogspot.com
Nov 02, 2006 12:55 | #8 Right I've had another go by dropping down the exposure is this any better (or am I flogging a dead horse)... Just need to know how to get rid of those highlights in the water, can anyone give me a clue please.
montreal Goldmember 1,194 posts Joined Apr 2005 Location: Trondheim, Norway More info | Nov 02, 2006 14:02 | #9 MMhhh.... perhaps the first one was better anyway... now the water looks gray... It's okay to have some blown highlights... 5D - 17-40L, 70-200L f4, 50 f1.4, PowerShot A430
daniel_981 Member 104 posts Joined Jun 2005 Location: Temecula, CA More info | Nov 02, 2006 15:14 | #10 Thats a nice looking area. Is that water really cold? DSPhotos.com
AdamJL Goldmember 4,365 posts Likes: 13 Joined May 2006 Location: 'Straya More info | Nov 02, 2006 16:14 | #11 MAH wrote in post #2206112 Right I've had another go by dropping down the exposure is this any better (or am I flogging a dead horse)... Just need to know how to get rid of those highlights in the water, can anyone give me a clue please. Take the shot again..
Nov 03, 2006 02:41 | #12 daniel_981 wrote in post #2206854 Thats a nice looking area. Is that water really cold?
Nov 03, 2006 02:42 | #13 AdamJL wrote in post #2207201 Take the shot again.. How come I knew this was going to be the answer
Nov 03, 2006 03:40 | #14 MAH, underexposure works best in camera I am affraid, it also looks like you have downed the highlight contrast too, which can lead to fake looking images. http://natureimmortal.blogspot.com
Seaboarder Senior Member 505 posts Joined Feb 2006 Location: Hilton of Cadboll, Highlands of Scotland More info | Nov 03, 2006 04:12 | #15 Be assured Mark that you are not the only one reading and learning. Paul
| Latest registered member was a spammer, and banned as such! 2641 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
