Thread started 18 Jan 2004 (Sunday) 12:44
How to focus right between 4f subject and everything behind
Crost_10D
Joined Jan 2004
Jan 18, 2004 12:44 |  #1
Hi everybody.
Just got my 10D from Gateway.... LLLoove it............
I've got 28-135mm IS Canon lens and now.....
I would like to ask you, how in the world I can take picture and have in focus everything the front subject and everything that's going to be behind. I've tryed different modes (A-dep included) and couldn't get sutisfactory results....
Thanks for your participation
timmyquest
Joined Dec 2003
Jan 18, 2004 12:57 |  #2
you mean like this?
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by ADVERTISEMENT
Your post is honestly a little confusing.
Capturing life a fraction of a second at a time
RichardtheSane
Joined Jun 2003
Jan 18, 2004 12:57 |  #3
You need to use Av mode, and set the aperture as high as you can get.
This will increase your Depth of Field (DOF).
What sort of subject are you trying to photograph?
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
PaulB
Joined Apr 2003
Jan 18, 2004 14:24 |  #4
Richard means high f number = small aperture = increased DoF.
Closer subject is you need increasingly smaller apertures to get a deep DoF.
Crost_10D
Joined Jan 2004
Jan 18, 2004 15:07 |  #5
Yes like that picture... But that cat's picture was taken to close...
I mean like picture of (for example) a lot of people and background.
You see, when I'm changing my aperture to high like 8, 16, 22 then my picture comes out dark and what should I do with it. I changed shutter speed it still to dark or out of focus the whole pic. Should I use flash light? ( Cause I was trying all that at home inside my living room and I was trying to catch the chair the table and the wall and the table in focus, but the chair and the wall out of focus?
Strange isn't it? Or may be everything is so close to the camera, but shouldn't be cause it's more than 2 feet from a camera........
WyzMan
Joined Oct 2003
Jan 18, 2004 15:27 |  #6
I'm guessing now but think that Crost_10D may be referring to using the 10D in full auto mode with all 7 AF points active. If this is the case, he/she may be pointing to a situation like this ....
Group of people, most of the focus points miss the subjects, focus obtained on a picture on the wall behind them.
I tend to have only the centre (yup - I'm English - not centER!), AF point active and compose that way. Focus centrally on the subject and if need be move off centre with the shutter release still half pressed - when composition is fine and dandy - press the release home.
Alan
timmyquest
Joined Dec 2003
Jan 18, 2004 15:30 |  #7
A smaller apature (8 is smaller then 4) will give you less light, and it will make more of the picture come into focus. That picture was taken with my apature wide open. If you want everything in focus then you'll need to close the apature.
To adjust for the lack of light that a small apature allows you can turn the ISO up, use more light (obviously) or a longer shutter speed.
scottbergerphoto
Joined Jun 2003
Jan 18, 2004 15:34 |  #8
I understand you to be asking, How can I get the subject and everything behind it in focus and nothing in front of it in focus. The difficulty answering the question you are asking lies in large part on understanding Depth of Field. When you focus on a subject, an area in front of the subject and behind the subject will be in focus. That's the depth of field. It is divided 1/3 in front of the subject and 2/3 behind. It can be on the order of inches or very large such as with landscapes. The smaller the aperture(larger f stop number) the larger the depth of field and vice versa. So technically, if you want to have the subject and everything behind it in focus, you would have to choose a small aperture f/16, f/22; use a depth of field calculator to determine the dimensions of the depth of field for the lens you are using,and focus 1/3 of the distance in back of the front most object you want in focus.
If anyone has a more elegant solution please feel free to educate me.
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
Crost_10D
Joined Jan 2004
Jan 18, 2004 15:41 |  #9
Alan
Well, I thought I said that I was using A-DEP
defordphoto
MKIII Aficionado
Joined Oct 2002
Jan 18, 2004 15:46 |  #10
Even with the smallest f-stop there is a limitation to DOF. You cannot, for example, focus on a bug at 6 inches and infinity.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Jan 18, 2004 16:09 |  #11
Sorry if this is old news for you, but just in case:
DoF (Depth of Field) means a "box" of acceptable sharpness, and inside that box focus point is the only actually sharp plane. If you have subject that is 3 meters deep and your DoF is 3 meters then you will have to focus to the middle of the object so that it is "covered" by the DoF.
Relation between aperture, focal lenght and distance is what you have to get familar with if you want to have control over your camera, so that your results get closer to what you wished.
Closing aperture (bigger f number) means getting less light in (darker) from smaller hole, resulting in longer/deeper DoF
Opening aperture (smaller f number) means getting more light in (brighter) from larger hole, resulting in shallower/shorter DoF.
Zooming in (going towards tele range) means DoF gets shallower. Zooming out (going towards wide angle) means DoF gets deeper.
Moving closer to subject (focus point distance is near) means DoF gets shallower. Moving further from subject (focus point distance is far) means DoF gets deeper.
How to use this info in practical situations? First you need to have some approximate data in your mind: how is DoF when I have 100mm at 2/5/10 meters? What about 50mm at 2/5/10 meters? What about 20mm at 2/5/10 meters? If you have no idea how the DoF actually IS you will miss a lot of shots - this really is exact science (DoF can not be fooled) but it is generally enough if you have in your mind some vague idea that
17mm f/2.8 at 2m gives you 170cm of DoF.
20mm f/2.8 at 2m gives you 110cm of DoF.
35mm f/2.8 at 2m gives you 40cm of DoF.
50mm f/2.8 at 2m gives you 20cm of DoF.
100mm f/2.8 at 2m gives you 10cm of DoF.
200mm f/2.8 at 2m gives you less than 1cm of DoF.
You don't need to know the exact figures. Just estimation - like 35mm at 2.8 covers "one human head" nicely from two meters. As you see from the list that when you go wider, the DoF gets drastically deeper. Notice that that change is not even between focal lenghts. So small change in focal lenght does a lot the wider you go.
As you see with f/2.8 you'd need to use 20mm to cover DoF worth of one armchair from 2m :)
The aperture change is more "effective" in centimeters when you go towards wider angle lenses.
17mm f/5.6 at 2m gives you 6.5m of DoF.
20mm f/5.6 at 2m gives you 3m of DoF.
35mm f/5.6 at 2m gives you 70cm of DoF.
50mm f/5.6 at 2m gives you 30cm of DoF.
100mm f/5.6 at 2m gives you 8cm of DoF.
200mm f/5.6 at 2m gives you 2cm of DoF.
17mm f/11 at 2m gives you 0.8m to infinity of DoF.
20mm f/11 at 2m gives you 1m to infinity of DoF.
35mm f/11 at 2m gives you 155cm of DoF.
50mm f/11 at 2m gives you 70cm of DoF.
100mm f/11 at 2m gives you 17cm of DoF.
200mm f/11 at 2m gives you 4cm of DoF.
Use http://dfleming.ameran​et.com/dofjs.html (external link) for browsing 10D DoF data.
The dilemma of daily SLR photography is that when you need to have more in focus, you'll get less light in. To fight this you have to either:
- slow down shutter speed
- use flash (which gets 'weaker' when you set f number bigger)
- raise ISO
- move away from subject
- use wider lens
Or any combination of above. There is simply no way out of it.
Of course when you shoot people you can ask them to move into tighter position, or when you shoot a jewelry collection you can arrange them so that they fall in DoF. You can do a lot by changing the camera angle and your shooting position.
Hope this was of any help to you.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Jan 18, 2004 16:14 |  #12
Crost_10D,
Welcome!
You're looking for a lot of knowledge - I recommend leafing some of the articles at this site:
http://www.luminous-landscape.com/tutorial​s/index.shtml (external link)
Also, you may wish to get hold of a good general photography book, such as "National Geographic Photography Field Guide" which has some very good information and illustrations to help explain the relationships between aperture, shutter speed, available light, and depth-of-field. I have that book and it is good. I still use it occasionally.
There's a lot of pieces to the puzzle that you need, and its hard to put them all together in a forum.
Tom
5D IV, M5, RP, & various lenses
robertwgross
Joined Nov 2002
Jan 18, 2004 18:11 |  #13
Yes, but at f/32, you can get a hell of a lot into focus.
I shoot landscapes where I have flowers in the foreground (at a few feet) and forest in the background (way out). I cheat. I use slow film. Too bad my digital Canon does not go lower than ISO 100.
---Bob Gross---
defordphoto
MKIII Aficionado
Joined Oct 2002
Jan 18, 2004 18:14 |  #14
Very true Bob. Yeah. I'd love to have ISO50 or heaven forbid; 25! I used to love shooting ASA25 film...
robertwgross
Joined Nov 2002
Jan 18, 2004 18:36 |  #15
That is why I still keep my Canon film camera loaded up with Velvia 50.
---Bob Gross---
3,896 views & 0 likes for this thread, 15 members have posted to it.
Latest registered member is vinceisvisual
901 guests, 177 members online
