D. Craig Flory wrote in post #2216387
I'm sorry but this one missed being a good portrait.
It totally lacks contrast and needs to be 300% deeper. And hi-key portraits are never created as head & shoulders portraits. The whole idea of hi-key is to have the white clothing show against the white background. Please try again.
Ok.
The original shot is from an available ligh candid photograh. It was severly altered within photoshop to get the results.
I mentioned I was using Brian Duckett's tutorial for getting me started....
http://www.duckettphoto.com/lessons/pencil/index.htm
He refers to the technique as a pencil portrait. I used the term "hi-key pencil portrait" since I thought it seemed accurate.
Brian Duckett's tutorial starts with a rather professional portrait setup including a studio light a reflector and a flash aginst a white background. Since I lack this I just used a pleasant head and shoulders candid and photoshopped out the busy background.
As for the lack of contrast, I intentionly used heavy handed dodging to achieve the look, which was recomended in the tutorial. I may have softened the ears too much and the hair to little, this is my first attempt so hopefully I will improve. as you say "please try again"
I am sorry if I used Hi-Key in an improper context, perhaps you can suggest some more accurate vocabulary I may use in future posts reguarding this type of process.
Also I am not aware of what is meant by "300% deeper", could you please explain it? and also what I might need to do to achieve this? I assume it is a in camera technique? Or might I be able to get it through post processing as well?
Thanks Craig, and everyone for your comments and sugesstions.
