Thread started 04 Nov 2006 (Saturday) 13:24
Need recommendation for CP filter...
Margie
Nov 04, 2006 13:24 |  #1
I need to get a CP filter for my sigma 10-20, 77 mm lens...and wondered which one you would recommend. I would like it to have front threads to accomodate my cokin holder...and understand it should be thin for this wide angle.
What would you suggest and why?
Thank you, Margie
Margie
Canon Rebel XT/ Canon PS G6/ 28-75 F2.8 Tamron/ 18-55 Kit /
100 F2.8 Macro/ 70-200F4 L Canon/ Canon 300 F 4 L IS/Sigma 10-20 F 4-5.6 /
1.4 II TC Canon
sugarzebra
Nov 04, 2006 13:28 |  #2
I would suggest Heliopan, B+W or Hoya. Be careful with Hoya as there are four or five different types(quality) of CPL's....I would only buy the Pro-1D or Super Pro 1D (HMC). I bought the Hoya Super Pro and its very good, however does vignette in the 10-14 mm range on my 10-22 lens. Others report no vignetting so maybe its just my technique!
Scott
Website & Blog (external link)
angryhampster
"Got a thick monopod?"
Nov 04, 2006 14:47 |  #3
If you're using a filter and a cokin P holder, you will vignette at wide angles. That said, go for a B+W thin filter.
Steve Lexa
Iowa City Wedding Photography (external link)
Tony-S
Nov 04, 2006 15:09 |  #4
Margie wrote in post #2215936 (external link)
Thank you, Margie
I use Sigma's (external link) for this lens, as well as my 17-40L. Multi-coated, thin and threaded.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
syntrix
Nov 04, 2006 15:20 |  #5
Tony-S wrote in post #2216308 (external link)
+1 same here. You can get it from sigma4less.com for about 100 bucks. The front does indeed have some threads on it, as you can see here:
IMAGE: http://www.lasvegastech.com/sig_wide_cp.jpg
moew!!!!!
Margie
Nov 04, 2006 19:09 as a reply to  @ syntrix's post |  #6
Thank you all...I will check out those brands. My problem is that I picked up a Hoya thin multicoated filter the other day and didn't realize that it would be a problem that it had no front threads. I have a new cokin filter system for this lens and I cannot put it on without the front threads.
I will look into some of the ones you have suggested...
Margie
Margie
1.4 II TC Canon
Cobra351
Joined Sep 2003
Nov 04, 2006 19:11 as a reply to  @ Margie's post |  #7
I like the Hoya Pro 1 CP (77mm), works well for me. Deals can be found on Ebay.
Canon 5D Mark II
Canon 40D - Infrared Modified (www.lifepixel.com (external link))
Canon Lenses: 17-40, 24-105 f/4 IS, 100 2.8 IS Macro, TS-E 90, 70-200 f/4 IS, 100-400 IS
Canon EF25 II , EF 1.4x II
Smith & Wesson M&P 340CT .357 Magnum
Double ­ Negative
*sniffles*
Nov 05, 2006 09:00 |  #8
Stick with Heliopan or B+W, followed by a Hoya Pro1.
I use Heliopans, personally. They recently moved all their frames to "slim" types - and maintain threads on the front for other filters, rubber lens hoods or lens caps.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
farrukh
Nov 05, 2006 10:31 |  #9
I use Sigma CPL (NEW DG WIDE) it has threads on front.
5D Mark II + 40D | Lenses: Sigma 150-500mm BigmOS / Canon 24-105mm F4L IS / Canon 70-200 F4L IS / Canon 85mm 1.8 / Sigma Macro 70mm f/2.8 EX / Sigma 10-20mm EX / Canon 50mm f/1.8 II / Sigma 1.4x APO TC / Kenko 2x PRO300 DG. Lighting: Canon 580EX II + Metz 58 AF-1 + Sunpak 383...
Margie
Nov 05, 2006 10:44 as a reply to  @ farrukh's post |  #10
I decided this morning to definitely take back the Hoya I purchased last week without front threads.
I will look into all of your suggestions...Hopefull​y I will find one under $150. or even $125. I don't think I can ask for anymore than that.
This photography is an expensive hobby!
Thank you for all your suggestions....Margie
Margie
1.4 II TC Canon
1,617 views & 0 likes for this thread, 8 members have posted to it.
2770 guests, 139 members online
