Thread started 04 Nov 2006 (Saturday) 22:02
Great memory, technically quite bad portrait - needs help!
R.ticle ­ One
Nov 04, 2006 22:02 |  #1
Hey everybody, I have here a portrait shot of which is a part of a great memory for me, but it was a poorly taken shot. I've no idea of my camera's settings at the time, but it was taken on a point and shoot on a sunny day with a ten second timer with the camera badly positioned on a slanted surface. The original was very dark, with a more blown out sky, on an angle (which I fixed by rotating and cropping), and quite unbalanced. I have already had a go with layers of varying shadow and highlight work, levels, selective coloring, etc. Also, the skin tones were quite reddish to begin with. What I have is a better result than before, but I still think that the contents of the shot can be technically improved on, further. It's still noisy, and there is weird color noise, like reddish splotches in some people's faces, on blue tshirts, etc.
I'd greatly appreciate any PS CS2 advice (bearing in mind that I've not had the program for more than a few days and it's a big step up from what I used to dabble and mess around with), and wouldn't say no to edits demonstrating something improved. My monitor is calibrated within my current means, with Adobe Gamma.
Thanks very much for any help. Below are the original shot, followed by my edit.
R.ticle One
IMAGE: http://i122.photobucket.com/albums/o268/R-Ticle_One/BasketballGroup2.jpg
IMAGE: http://i122.photobucket.com/albums/o268/R-Ticle_One/BasketballGroupOriginal.jpg
Quite new to all this.
Gear: Point and Shoot Panasonic DMC-LZ5. :oops: Tiny little No Name Tripod. Photoshop CS2.
Image Editing is just fine.
Terrywoodenpic
Nov 05, 2006 08:43 |  #2
I prefer the original to the changed one.
I have tried to make lesser changes
I used magic brush to select each shadow area of each face then used curves to change contrast darkness and colour in each face. Just a little.
It is much better to use fill flash with this sort of shot against the light or side lit.
Terry_______________
Over 60 years in photography
wasted money cameras never on film.
R.ticle ­ One
Nov 05, 2006 08:54 |  #3
Terrywoodenpic wrote in post #2219393 (external link)
Hey, thanks! That doesn't look too bad, what you posted. My edit has a slightly yellowish or washed out cast to it. I will try what you did as an alternate method. Yep, fill flash would have been the best idea, unfortunately (or fortunately, rather, ;) ), we were all having so much fun and dealing with 5 or so cameras on the same small surface trying to take a shot, that I neglected to think of it!
Appreciate your help and advice. :)
R.ticle One
942 views & 0 likes for this thread, 2 members have posted to it.
1548 guests, 170 members online
