Your plan to use a wide angle is good as the problems are less and it is much safer (telephoto lens into the sun is a real danger to your retina and the camera's sensor).
From my limited experience:
1. Obscure the sun with a branch or catch the moment it peeks over the horizon. The closer it is to a point source of light the better.
2. Use a small aperture - point sources of light turn into attractive stars, not blobs.
3. Use ND grads - 3 stops minimum, maybe up to 6 stops. I once saw my photog friend Andy use 9 stops!! That way you have a chance of retaining detail in the darker areas.
4. Shoot in RAW so that you can do a conversion which is underexposed for the sky and another for the darker areas.
5. If you don't understand 4 just underexpose the whole shot by 1/3 to 1 stop.
Above all experiment! If you get a good result, post it here (with details) so we can all learn.
