Thread started 05 Nov 2006 (Sunday) 12:09
Help please with lens decision
jbear29
Nov 05, 2006 12:09 |  #1
Please provide advice and comments on opinion of which lens I should purchase. I need a lens in the 25-80mm range and was considering the Tamron AF 28-75mm f/2.8 XR Di Autofocus Lens for around $325 new or a used Canon EF 28-70mm f2.8L for around $625 in great shape. Any advice or recommendations would be greatly appreciated. I have a canon 20D camera.
steved110
Nov 05, 2006 12:19 |  #2
The L lens will be the best quality optically and build wise, but do you really want to spend so much $ on a used lens that has been superceded anyway?
Also, starting at 28mm is not very wide on a crop camera.
Tamron, tokina and sigma all make fast f/2.8 zooms that start at 16-18mm and go to 50-55mm with a constant f/2.8 aperture, at reasonable prices, similar to what you state for the 28-75mm. I think you'd find these fill the niche better, unless you are sure you don't want a wider angle.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
Mr. ­ Clean
Nov 05, 2006 12:22 |  #3
The Canon is built better, might have better IQ, does have faster focusing, and fll time manual focusing. It's also 300 bucks more. If you can afford the 28-70 it's a good lens. It's an oldie but a goodie. I think I'd go for the Tamron though, or take the plunge and get the 24-70L.
Either way though, you can't lose I don't think.
Mike
some shots @ Zenfolio (external link)
perfect_pixel
Nov 05, 2006 12:25 |  #4
Ha! Took a while to find but I knew that I had seen this same question somewhere:
http://www.photography​-on-the.net …anon+28-70+v+tamron+28-75
Hope this helps!
Steve
"...Most things in life are moments of pleasure and a lifetime of embarrassment; photography is a moment of embarrassment and a lifetime of pleasure..." ~Tony Benn
977 views & 0 likes for this thread, 4 members have posted to it.
2765 guests, 140 members online
