Have been thinking about placing an access hole in my lens hood to allow me to easily adjust my polarizer. Has anyone tried this and if so can they report out good results?
pcDigiMan Senior Member 300 posts Joined Apr 2005 Location: USA, S. E. Michigan More info | Nov 05, 2006 22:32 | #1 Have been thinking about placing an access hole in my lens hood to allow me to easily adjust my polarizer. Has anyone tried this and if so can they report out good results? Cheers,
Briancd Senior Member 345 posts Joined Apr 2005 Location: Sanctuary Point, NSW, Australia - 2 hours south of Sydney More info | Nov 05, 2006 22:56 | #2 Would that not defeat one of the purposes of the lens hood and allow stray light to enter through the lens? In manual I use the * button for focusing so I do this first then set the CP filter and then set my exposure. Brian
Nov 06, 2006 13:51 | #3 I am picturing a opening large enough for the tip of your finger to rotate your polarizer and the hole would need to be blocked... possibly by your hand or even a piece of tape or Velcro. Cheers,
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Nov 06, 2006 13:53 | #4 I use a polarizer with my 17-40 and hood all day long. No need for a hole luckily since it's a small hood. people will always try to stop you doing the right thing if it is unconventional
I don't think you need the hood while using a polarizer.
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Nov 06, 2006 14:05 | #6 You can still get flare with a polarizing filter. people will always try to stop you doing the right thing if it is unconventional
Briancd Senior Member 345 posts Joined Apr 2005 Location: Sanctuary Point, NSW, Australia - 2 hours south of Sydney More info | Nov 06, 2006 15:06 | #7 pcDigiMan wrote in post #2225102 I am picturing a opening large enough for the tip of your finger to rotate your polarizer and the hole would need to be blocked... possibly by your hand or even a piece of tape or Velcro. I want to start using my polarizer more and it is kinda a pain reaching in through the hood when you are taking a bunch of shots where you are not constantly focusing on one area of light. I end up with too many finger smudges when I reach in to the polarizer with the hood on. I can try to keep my fingers cleaner : ) I am tempted to try something with my hood ... these things are costly if you mess one up. I see what you mean. Maybe then the best place would be on the underneath side. Brian
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Nov 06, 2006 15:29 | #8 I use a CPL with the 70-200mm and 24-70mm regularly and it IS a pain in the butt to move the CPL, but it's possible. Just pay attention so you don't reach in and touch the filter/front element - something I do from time to time. D'ohhh. La Vida Leica!
yenoram Member 239 posts Likes: 2 Joined Jun 2002 Location: Canada More info | Nov 06, 2006 17:45 | #9 I recall a few years back a poster on one of the Canon forums (FM?) did this using a Dremel tool. He posted pictures of the end product and it actually looked pretty good. At the time he was pleased with how it worked and didn't have any problems with stray light. An opening on the underside would make the most sense since this is the least likely source of stray light - that is until you change the camera's orientation from landscape to portrait.
Nov 06, 2006 18:05 | #10 Thanks for the feedback. Think I will try one of those rubber screw on hoods from e-bay. Cheers,
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Nov 06, 2006 18:11 | #11 pcDigiMan wrote in post #2226366 Thanks for the feedback. Think I will try one of those rubber screw on hoods from e-bay. What lens are you planning to put this on? Not all lenses lend themselves to rubber lens hoods - zooms can be problematic especially. La Vida Leica!
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Nov 06, 2006 19:00 | #12 I've thought of the same thing myself. A small hole,or notch, on the underside of the hood would allow you to turn the cpl, and shouldn't have any effect with regards to flare.
Nov 06, 2006 19:34 | #13 Double Negative wrote in post #2226418 What lens are you planning to put this on? Not all lenses lend themselves to rubber lens hoods - zooms can be problematic especially. Want to use it on my 70-200 2.8L and my 24-70 2.8L. Do you have any experience with these? Cheers,
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Nov 06, 2006 20:32 | #14 pcDigiMan wrote in post #2226743 Want to use it on my 70-200 2.8L and my 24-70 2.8L. Do you have any experience with these? You can probably get away with it on the 70-200mm, but on the 24-70mm because of the hood design it doesn't work well, IIRC. The problem is vignetting at the wide end and not being nearly long enough on the tele end. La Vida Leica!
dave13 Member 145 posts Joined Feb 2006 More info | I think it was Sigma that made a hood for one of their lenses with a polarizer slot already cut out. Making one yourself isnt out of the question.
| Latest registered member was a spammer, and banned as such! 2893 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
