Thread started 06 Nov 2006 (Monday) 04:01
How to remove a filter from lens?
segasaturn
Nov 06, 2006 04:01 |  #1
Hi all. This is going to sound very strange, but the used 300D that I bought came with the kit lens EFS 18-55 and on it came a filter. I would like to remove the filter because there is dust between it and the lens. The filter says "HAZE 58mm (UV) Korea".
How do I remove this filter? I've tried twisting it counter clockwise and it was no good. Am I doing something wrong?
Thanks,
Micah
Choderboy
I like a long knob
Gallery: 185 photos
Nov 06, 2006 04:13 |  #2
They can get jammed. Just like any thread.
Rubber band can help - makes it easier to get a grip on the filter.
Worthwhile removing lens from camera to save camera from any harm during the struggle :)
Dave
Image editing OK
tim
Light Bringer
Nov 06, 2006 05:13 |  #3
Only bother if you can see the dust in your images... which will probably only happen at F12 or narrower (eg F16/F22).
Neilyb
Gallery: 23 photos
Nov 06, 2006 05:15 |  #4
Put a rubber glove on, to grip the filter! :)
http://natureimmortal.​blogspot.com (external link)
http://www.natureimmor​tal.com (external link)
Choderboy
I like a long knob
Gallery: 185 photos
Nov 06, 2006 06:29 as a reply to  @ Neilyb's post |  #5
Agree with Tim - don't worry about the dust. But better to get it sorted.
If it's stuck , it's not going to get less stuck with time. It will only get more stuck :oops:
It's not an immediate problem , but a camera shop should be able to help you out , hopefully at no cost.
Dave
Image editing OK
Wilt
Nov 06, 2006 06:41 |  #6
The trick to removing filters is partially to improve the grip on it with rubber glove or rubber band, but also to try to not squeeze too much so as to distort the roundness of the filter while trying to remove it...squeezing in one direction (12 and 6 o'clock, for example) can bow it in the other (3 and 9 o'clock) and make the binding worse! If you can get a 4 finger grip around the clock that can help you get it off.
You are experiencing the problem of an aluminum filter ring binding into aluminum threads on the lens, one big reason why those considering polarizing filters are wise to spend a bit more for a filter with brass ring rather than aluminum, since getting polarizers off is made even more difficult by the spinning part of the filter!
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Nov 06, 2006 06:59 |  #7
Sometimes when trying to remove a tight filter you tend to sqeeze it hard. This presses the sides in and tightens it, making it harder to remove. Try gripping it as lightly as possible.
Photos from my travels (external link)
Canon EOS R6 MkII | Canon EF 24-70mm f/4L | Canon RF 100-500mm f/4.5-7.1L | Samyang 14mm f/2.8
1,936 views & 0 likes for this thread, 6 members have posted to it.
916 guests, 145 members online
