Thread started 06 Nov 2006 (Monday) 14:07
CP for sigma 10-22
azpix
Nov 06, 2006 14:07 |  #1
I have a sigma 10-22 that I want to get a CP for. Is there are special type of CP or anything I need to consider since this is a wider angle lens?
Much thanks,
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
Thordic
Joined Jan 2005
Nov 06, 2006 14:15 |  #2
I purchased a rather pricy CP for my Sigma 10-20mm when I got the lens. Cost me around $170.
I wish I had done more research, or thought about basic physics. CP's work with the angles that light hits the lens. But a ultra wide angle lens lets in light from a HUGE array of angles. CP's don't function well under these conditions.
For example, you may want to get a nice blue even sky. However, due to the fact the light is hitting from such a wide angle, you'll get half a dark blue sky and half a light blue sky (for example).
So I ended up trading the CP for my CompuTrekker and havn't looked back. Aside from some speciality use with reflections, I find its easier to just photoshop a gradient into the sky to make it nice and blue.
20D w/ Battery Grip + 300D w/ Battery Grip + Sigma EF-500 DG Super + Sigma 30mm 1.4 + Canon 50mm 1.8 + Sigma 24-70mm 2.8 + Tamron 75-300mm + Sigma 10-20mm + Canon 70-200 2.8L + Sigma 50-500mm DG + Manfrotto 679B Monopod + Manfrotto 3011BN Tripod + Manfrotto 484RC2 ballhead + Dynatran ATH918S Pistolgrip Ballhead
All jammed into a Rolling CompuTrekker AW and Crumpler 6 Million Dollar Home
Jon
Joined Jun 2004
Nov 06, 2006 14:18 |  #3
Subject to posts from people with the 10-20 Sigma who can name specific filters:
Ultrawide angle lenses are prone to vignetting at the wide end unless you get thin CPs.
A polarizer on ultrawide wil give you different effects across the frame just because it covers such a wide angle. Polarization effect in the sky's strongest at 90 deg from the sun angle and weakest along the sun's incoming angle. A 10-20 covers almost 110 deg., so you'll have a lot of sky that's not very strongly affected along with the most affected parts.
Edit: What Thordic said. Or consider some nice neutral density grads.
Jon
Cocker Spaniels
Thordic
Joined Jan 2005
Nov 06, 2006 14:22 |  #4
Yeah, I forgot to mention that you may want to look in ND/Graduated filters.
I'm going to try to get a Cokin set out of my GF for christmas. :)
765 views & 0 likes for this thread, 3 members have posted to it.
CP for sigma 10-22
2893 guests, 138 members online
