Thread started 07 Nov 2006 (Tuesday) 15:44
Filter glass?
circa
Nov 07, 2006 15:44 |  #1
I have a Tiffen 77mm filter glass for "protection" on my 10-22mm Canon lens because I shoot skating and don't want it to get hit, but I'm curious as to whether or not the glass on the filter is the same quality of my Canon lens and if it isn't is it hendering my photo's quality?
wonderful skateboard adventures:
http://www.flickr.com/​photos/wjphoto/ (external link)
www.fotophun.blogspot.​com (external link)
chaosbunny
Nov 07, 2006 15:47 |  #2
i'm wondering the same thing
Thordic
Joined Jan 2005
Nov 07, 2006 15:51 |  #3
The definitive answer is: Maybe.
20D w/ Battery Grip + 300D w/ Battery Grip + Sigma EF-500 DG Super + Sigma 30mm 1.4 + Canon 50mm 1.8 + Sigma 24-70mm 2.8 + Tamron 75-300mm + Sigma 10-20mm + Canon 70-200 2.8L + Sigma 50-500mm DG + Manfrotto 679B Monopod + Manfrotto 3011BN Tripod + Manfrotto 484RC2 ballhead + Dynatran ATH918S Pistolgrip Ballhead
All jammed into a Rolling CompuTrekker AW and Crumpler 6 Million Dollar Home
rent
Nov 07, 2006 16:47 |  #4
is yours a wide angle (thin, no front thread) or regular tiffen 77mm? if regular, it may cause vignetting when shooting at the wide end.
i don't believe tiffen glass UV filters are mulitcoated. they can degrade your image by causing flare or ghosting, especially when shooting into a strong light source.
why not do a simple test shooting the same scene with and without your filter? you might want to pick a scene where the sun (or a light source) is just outside of your view and then check the resulting image and compare for flares.
my quick answer is to either not use a filter, or use one that is multi-coated and is designed for wide angle lens (thin). B+W MRC, Hoya Multicoated and Heliopan are the usually recommended.
-alex
http://portfolio.alexj​iang.com (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Nov 07, 2006 18:17 as a reply to  @ rent's post |  #5
I don't think most filters will stop a slap shot, (if you are shooting hockey) but if you buy a filter buy the best you can afford. 77 mm is a very common size so you can use it on many lenses, especially Ls.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Double ­ Negative
*sniffles*
Nov 07, 2006 23:52 |  #6
Canon filters are rebranded Tiffen - which by and large, stink.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
1,629 views & 0 likes for this thread, 6 members have posted to it.
Filter glass?
2893 guests, 137 members online
