Hey everyone....
any good links, I'm not all grasping this one yet?:o
Also, OT somewhat but my Pro1 has a 7.2mm-50.8mm f2.4-f3.5L but I thought it was called a 28mm-200mm? Then....where would I be in comparision using an XT with a 50mm f1.8 prime
slyone Senior Member 626 posts Joined Sep 2006 Location: Upstate,N.Y. More info | Nov 08, 2006 11:16 | #1 Hey everyone.... 40D, 70-200 f/2.8L, Tamron17-50mm f/2.8 XR Di-II, EX-580,Canon 1.4tc
Billginthekeys Billy the kid 7,359 posts Likes: 2 Joined Nov 2005 Location: Islamorada, FL More info | Nov 08, 2006 11:31 | #2 okay. P&S's have very small sensors. thus use lens sizes that a 35mm couldnt use. the real mm length of the lens is 7.2-50.8mm, but since that really doesnt tell you much about what shots its going take, they also express the effective focal length it will give in 35mm terms. in this case 28-200mm. Mr. the Kid.
runninmann what the heck do I know? More info | Nov 08, 2006 12:18 | #3 To amplify what Bill said and to answer your question about the 50mm on an XT, since the XT is 1.6 crop, the FOV with the 50 is the same as 80mm on FF. Based on the focal lengths and equivalents you provided for the Pro1, it has about a 4:1 crop (200mm:50.8mm), so in order to have the same FOV as 80mm on FF (or 50mm on XT), you would be at 20mm on the Pro1.
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Nov 08, 2006 17:03 | #4 If your Pro1 has the 35 mm equivalent of a 28-200 mm lens, you have to divided the numbers by 1.6 to get the equivalent focal length for your XT. That would be a 17-125 mm lens. Canon does not make a 17-125 f/2.4-3.5 lens. This is because it is easier to design quality lenses with a wider zoom range and wider aperture for small sensors because of the smaller image circle required.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | When you are at the short end of the lens on a P&S (7.2 or 7.3 depending on the camera) that works out to be about the equivalent of a 35mm lens. Robert
Billginthekeys Billy the kid 7,359 posts Likes: 2 Joined Nov 2005 Location: Islamorada, FL More info | Nov 08, 2006 17:20 | #6 TMR Design wrote in post #2236172 When you are at the short end of the lens on a P&S (7.2 or 7.3 depending on the camera) that works out to be about the equivalent of a 35mm lens. not always. the S80 is 28mm for one. Mr. the Kid.
Boy...I wish it didn't have to be so confusing.. 40D, 70-200 f/2.8L, Tamron17-50mm f/2.8 XR Di-II, EX-580,Canon 1.4tc
runninmann what the heck do I know? More info | Nov 09, 2006 00:13 | #8 slyone wrote in post #2237653 Boy...I wish it didn't have to be so confusing.. I also saw something about "constant Aperture" I assume this refers to a "prime lens" ![]() Not necessarily. A prime lens is a non-zoom lens, that is one focal length, such as 50mm f/1.4. It is a constant aperture lens. Constant aperture is normally used in describing a zoom lens whose maximum aperture does not decrease as focal length increases. You may see a lens referred to as, for example, 70-300 f/4.0-5.6. This means that at 70mm the max aperture is f/4.0, but as you zoom to longer focal lengths, the max aperture decreases, at some rate, until, at 300mm the max aperture is f/5.6. This is a variable aperture zoom. If the lens is, for example, a 70-200 f/2.8, then the max aperture is f/2.8 throughout the zoom range.
very good, Thanks for the brief clarification 40D, 70-200 f/2.8L, Tamron17-50mm f/2.8 XR Di-II, EX-580,Canon 1.4tc
KevC Goldmember 3,154 posts Joined Jan 2005 Location: to More info | Nov 11, 2006 13:17 | #10 ScottE wrote in post #2236130 Hopefully Canon will come out with something like a 50-200 f/2.8 IS EF-S to better compliment the 17-55. 55-200/2.8IS would be perfect for crop bodies! Too much gear...
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Nov 11, 2006 16:16 | #11 runninmann wrote in post #2237717 Not necessarily. A prime lens is a non-zoom lens, that is one focal length, such as 50mm f/1.4. It is a constant aperture lens. Constant aperture is normally used in describing a zoom lens whose maximum aperture does not decrease as focal length increases. You may see a lens referred to as, for example, 70-300 f/4.0-5.6. This means that at 70mm the max aperture is f/4.0, but as you zoom to longer focal lengths, the max aperture decreases, at some rate, until, at 300mm the max aperture is f/5.6. This is a variable aperture zoom. If the lens is, for example, a 70-200 f/2.8, then the max aperture is f/2.8 throughout the zoom range. All primes are constant aperture, but not all constant aperture lenses are primes. Let's not revive the old argument about the meaning of "prime lens". I know some people who will argue that your prime lens is the lens that you use most of the time. That could be a 50 mm f/1.4 or a 24-70 f/2.8 if that is the lens that you use more than any other. You have to be very carefull to use the phrase "fixed focal length" when talking about prime lenses around them.
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Nov 11, 2006 16:20 | #12 KevC wrote in post #2248426 55-200/2.8IS would be perfect for crop bodies! //edit: Or even 55-125/2.8IS to make it smaller and compete with the Sigma 50-150/2.8 //edit2: giving it a 88-200mm 35mmFOV equivalent I was hoping that Canon would be able to make a 50-200 f/2.8 EF-S. They currently make a very good 70-200 f/2.8 for full frame bodies. With EF-S they do not have to cover as wide an image circle so I was hoping they could maintain the same quality and increase the focal length range. What ever they make it should start at 50 or 55 and go as long as feasible.
rdenney Rick "who is not suited for any one title" Denney 2,400 posts Likes: 3 Joined Jun 2003 More info | Nov 11, 2006 18:26 | #13 A lens has a certain magnification power when focused on infinity. Lenses with a longer focal length have to be farther away from the film or sensor to focus at infinity, and thus create a larger projection of the image. Lenses with a shorter focal length are closer to the film or sensor when focused at infinity, and therefore create a smaller projection of the image.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Nov 12, 2006 08:35 | #14 ScottE wrote in post #2248924 Let's not revive the old argument about the meaning of "prime lens". I know some people who will argue that your prime lens is the lens that you use most of the time. That could be a 50 mm f/1.4 or a 24-70 f/2.8 if that is the lens that you use more than any other. You have to be very carefull to use the phrase "fixed focal length" when talking about prime lenses around them. Then they're referring to their "primary" lens, not their "prime" lens. Jon
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Nov 12, 2006 10:36 | #15 Jon wrote in post #2251536 Then they're referring to their "primary" lens, not their "prime" lens. YOU tell them. I have given up.
| Latest registered member was a spammer, and banned as such! 2846 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
