Thread started 09 Nov 2006 (Thursday) 12:15
Metering Modes? 30D.
JaGWiRE
Nov 09, 2006 12:15 |  #1
I have a 30D and have yet to cross the boundary past evaluative metering. I haev no idea where to begin and what mode to use for what sort of scenes. Any helps or links are greatly appreciated.
Canon EOS 30D, Sigma 30 1.4, Sigma 10-20, Sigma 105 Macro, 135L, 430ex, Lowepro Mini Trekker AW, Manfrotto 3001pro w/486rc2 and 804rc2 head, Manfrotto 681 w/ 3232 head.
http://www.brianstar.s​mugmug.com (external link)
led ­ hed
Nov 09, 2006 12:19 |  #2
generally we use 'evaluative' but feel free to read the manual for times when other metering modes are effective.
Rob - "a photographer is a painter, in a hurry!"
Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS
yenoram
Joined Jun 2002
Nov 09, 2006 12:26 |  #3
I generally use evaluative. As an example of when I switch metering modes, I shoot an annual stage production and for that I switch to partial for shooting because spotlights are used to highlight the subject and backgrounds are often dark. This ensures that the subject is properly exposed which would not be the case if evaluative was used. I have a 20D so the best I can do is partial metering; with your 30D you'd have the option of using spot metering.
JaGWiRE
Nov 09, 2006 14:23 |  #4
yenoram wrote in post #2239711 (external link)
Heh, I see.
I definitley need to take a glance through my manual to try and help me remember the difference between all the metering modes, although I believe it is very basic and doesn't give examples of situations where each mode would be useful.
Hermeto
Nov 09, 2006 14:26 as a reply to  @ JaGWiRE's post |  #5
http://www.canon.co.jp …ng/enjoydslr/p_​3_012.html (external link)
montreal
Nov 09, 2006 14:29 |  #6
Get this book http://www.amazon.com …tal-Updated/dp/0817463003 (external link)
I don't know about the 30D's instruction manual, but in the case of the 300D, it explains how to switch between the different modes but not when to use them.
5D - 17-40L, 70-200L f4, 50 f1.4, PowerShot A430
JaGWiRE
Nov 09, 2006 14:46 |  #7
montreal wrote in post #2240138 (external link)
The sad part is I have that book and have read through it :(.
Thanks for that link, looks good, I'll take a closer look at it later.
Hermeto
Nov 09, 2006 14:48 as a reply to  @ JaGWiRE's post |  #8
It is not the best explanation, but it will set you in the right direction..
montreal
Nov 09, 2006 14:52 |  #9
JaGWiRE wrote in post #2240203 (external link)
Perhaps you need to read it again from cover to cover :p
It helped me understand a lot of stuff and now I shoot in 'M' most of the time.
JaGWiRE
Nov 09, 2006 14:55 |  #10
montreal wrote in post #2240228 (external link)
Yeah, I do need to re-read it, I almost always shoot manual less I have a reason for shooting in TV or AV. As great a book it is, it has a lot of information and unfortunately I am good at forgetting stuff, haha.
TMR ­ Design
Joined Feb 2006
Nov 09, 2006 15:38 as a reply to  @ JaGWiRE's post |  #11
Go to the link Hermeto gave. It explains it and shows photo examples. I'm still learning about metering and even when people offer explanations as to how they use it and why, it does not really click until you do something that shows you on your own camera in your hands.
Robert
JaGWiRE
Nov 09, 2006 20:15 |  #12
TMR Design wrote in post #2240381 (external link)
Yeah, definitley.
montreal
Nov 09, 2006 20:25 |  #13
JaGWiRE wrote in post #2240244 (external link)
So you're saying you shoot manual with the evaluative metering mode? I don't understand how you go about doing that... On the 300D it's not even an option (manual goes with "center-weighed)... but even if it was I don't think I would ever do that... how do you know what to compensate for?
JaGWiRE
Nov 09, 2006 20:28 |  #14
montreal wrote in post #2241371 (external link)
Yeah I shoot with the evaluative. Usually works well, sometimes not so well. That's why I started this thread, but I'm guessing I'll have to experiment for myself. With other modes I've had weird results, overexposed or underexposed subjects.
montreal
Nov 09, 2006 20:34 |  #15
JaGWiRE wrote in post #2241377 (external link)
The problem with evaluative (or so I'm told... I'm far from being an expert) is that the camera takes decisions of which you are not aware. This works for most pics but in sometimes tricky conditions you need to expose for a certain specific part of your frame (f. ex. a backlit tree) and then adjust your exposure from there. With evaluative, the camera decides what it wants to do so you can try to adjust as much as you want, you don't know what the starting point is so you're in the dark...
2,084 views & 0 likes for this thread, 7 members have posted to it.
2271 guests, 136 members online
