Thread started 10 Nov 2006 (Friday) 11:32
I have no clue about filters..
skimmilk68
Joined Dec 2004
Nov 10, 2006 11:32 |  #1
Is there a specific thread in here or perhaps a tutorial website that'll tell me exactly what the functions of different types of filters are and how I should use it etc... ?
-canon 350d
-Tamron 28-75 f.28
more to come...
Citizen_Insane
Nov 10, 2006 12:04 |  #2
I wouldn't mind this info either...although if you go on google, there is a fair amount of info available. Have you tried doing some research?
Gear
gasrocks
Nov 10, 2006 12:06 |  #3
One nice thing about shooting digital is that you can replace many filters with software in post processing. Other than a protective UV filter over each lens and perhaps a C. Poliz. there aren't too many filters you need.
kevin_c
Nov 10, 2006 12:10 |  #4
For landscapes a Graduated Neutral Density filter can be useful (ND Grad) This stops the sky from being over exposed.
As gasrocks says, most filters can re replicated in PS.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
skimmilk68
Joined Dec 2004
Nov 10, 2006 12:22 |  #5
do you guys have a UV filter on all your lenses?
-canon 350d
-Tamron 28-75 f.28
more to come...
equetefue
Gallery: 230 photos
Nov 10, 2006 12:26 |  #6
I heard the best filter is the 81A and moose's filter. How true is that. It has something to do about the Kelvin temp on a bright day giving a blue tint to your pics..
can somone elaborate on this.
http://www.Photo-Galleria.com (external link)
Powered By Canon
EOS R l 5D MkIV l 7D MkII l 5D l 30D IR l 500mm f4 L IS l RF 24-105mm f4 L l 50mm f1.8 l 17-40mm f4 L l 135mm f2 L l 100-400mm f5.6 L L IS II l 100mm f2.8 USM Macro l EF 1.4x III l EF 2.0x III l 580EX II
kevin_c
Nov 10, 2006 12:27 |  #7
skimmilk68 wrote in post #2243986 (external link)
I don't, unless I want some protection from the elements (sand/dust etc.)
There are countless threads on 'filters vs hoods' for lens protection - PLEASE don't start another one PLEASE!!! :):):)
-- K e v i n --
jr_senator
Nov 10, 2006 12:32 |  #8
kevin_c wrote in post #2244008 (external link)
Kevin, it's been almost a hour since someone has started a new one. BTW, I don't degrade my lens' IQ with filters either.
JohnJ80
Nov 11, 2006 08:45 |  #9
gasrocks wrote in post #2243924 (external link)
For Digital, really the only filter you need is a polarizer - the effect it produces cannot be replicated in post processing. Otherwise, using warming or colored filters in PP is much easier than fooling with them in the field. As well, it will act like a 1-1.5 stop ND filter which is useful if you are shooting in very bright conditions.
If you want to fool with graduated ND, they can be interesting but you can also do the the same thing with the HDR capability in CS2.
As far as buying ANY filter for digital, make sure it is multicoated to reduce reflections and flare. See:
UV and CP Filter tests (external link)
I use a UV filter in front of all of my lenses, but then I shoot in some places where there is stuff flying in the air - alpine skiing and yacht racing (snow and spray) also a lot on beaches (sand). So, I'm a UV guy.
I also don't use one on my 300mm f/4 because the lens hood is so deep that the lens is very well protected. I also shoot with it for soccer games often in the late afternoon when flare can be a problem.
In selecting one, I advocate getting the very best. The lenses now days have very high quality glass. It makes no sense to put a lower quality piece of glass in front of them. So, I use B+W filters. They are expensive, but worth it, IMO.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
canonloader
Gallery: 6 photos
Nov 11, 2006 08:55 |  #10
Also, be aware that cheap filters can and will leave artifacts in the final image that you can't get rid of, particularly on the 100-400L IS lens. Cheap filters will leave diagonal lines in the bokeh behind the subject your focused on. You can even see them through the viewfinder once you know what to look for.
I was worried about that when I ordered my CP for the big lens, but it's a Canon brand and works flawlessly. It's also made with extremely high quality workmanship.
Mitch- ____...^.^...____
Master-9
Nov 11, 2006 09:33 |  #11
jr_senator wrote in post #2244023 (external link)
TOO LATE!!!!!! What do you mean image degrading:mad:
From Decatur Georgia(USA)
Canon 40D+ BG-E2N, Canon 20D, Canon PowerShot G12, Canon PowerShot G7, Canon Rebel(Film)EF-S 18-55mm f4-5.6, EF 28mm f2.8, EF 50mm f1.8 Mk I, EF 85mm f1.8 USM, EF 24-70 f2.8L USM, EF 70-200mm f4L USM, Canon Speedlite 420 EX
962 views & 0 likes for this thread, 9 members have posted to it.
2848 guests, 137 members online
