Thread started 12 Nov 2006 (Sunday) 20:41
Lens Hood use with 85mm f/1.8
angryhampster
"Got a thick monopod?"
Nov 12, 2006 20:41 |  #1
I plan on picking up an 85mm f/1.8 within the next couple of weeks to add to my "collection," and was curious how much this lens tends to flare. Do most of you that use this lens use a hood as well? If so, what model?
THanks!
Steve Lexa
Iowa City Wedding Photography (external link)
SkipD
Joined Dec 2002
Nov 12, 2006 20:50 |  #2
You really should use a properly designed lens hood on ANY lens you use unless the hood makes taking the photo impossible or impractical (such as when shooting at one inch from the subject).
Skip Douglas
puddlepirate44
Nov 12, 2006 20:54 as a reply to  @ SkipD's post |  #3
Canon ET65 III is the hood, the cost, at Amazon is around $20.
Wag more, bark less.
Mr. ­ Clean
Nov 12, 2006 21:06 |  #4
I just got the lens hood for my 85 not too long ago. Had the lens for about a year without the hood and never had issues with flare. It all depends in how you shoot
Mike
some shots @ Zenfolio (external link)
JaGWiRE
Nov 12, 2006 21:09 as a reply to  @ Mr. Clean's post |  #5
I use some rubber thing the previously seller included. I like it, it even folds back.
Canon EOS 30D, Sigma 30 1.4, Sigma 10-20, Sigma 105 Macro, 135L, 430ex, Lowepro Mini Trekker AW, Manfrotto 3001pro w/486rc2 and 804rc2 head, Manfrotto 681 w/ 3232 head.
http://www.brianstar.s​mugmug.com (external link)
bolantej
Nov 12, 2006 21:29 |  #6
if you want protection for the front element, use a hood. I would not worry so much about flare.
DaveL
Nov 13, 2006 16:43 as a reply to  @ bolantej's post |  #7
I do have the standard hood but I don't really like the way
it snaps on and off... I did fnd a couple other options, Ritz
sells a rubber hood for $5.99 but it doesn't really offer protection
against bumps. Some ebay sellers sell petal type hoods
that screw into the 58mm threads for about $10 plus
shipping... but, then you can't put the lens cap on while
the petal is on...
Canon 5DSR, 5D MKIII, 6D, 1D Classic
Canon 300mm f/2.8L IS, 70-200 f/2.8L II, 85mm F/1.2L, 16-35L II,
Alien Bees B800 strobes, softboxes, pocket wizard X's
Gibson & Nash Guitars
Friedman Amps
superdiver
Nov 13, 2006 18:28 |  #8
You dont need one shooting indoors do you?
40D, davidalbertsonphotography.com
Newbie still learning
SkipD
Joined Dec 2002
Nov 13, 2006 18:32 |  #9
superdiver wrote in post #2258297 (external link)
I wouldn't use any lens anywhere without a properly designed rigid hood mounted to it unless that hood made taking the photograph impossible. An example of that would be a very close macro shot where the hood would hide the lighting from the subject.
A hood can prevent all sorts of contamination (from your own fingers, for example) or damage (from everyday knocking around) to a lens in addition to blocking stray light. Stray light is found indoors as well as out.
Skip Douglas
superdiver
Nov 14, 2006 00:47 |  #10
Would it reduce the amount of available light for shooting sports indoors noticebly?
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Nov 14, 2006 01:00 |  #11
Not a bit.
Mac users swear by their computers. PC users swear at theirs.
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Nov 14, 2006 01:00 |  #12
A hood does not reduce the amount of light available for a photograph. The hood simply keeps extraneous light from striking the lens and potentially having a negative impact on the image. And as Skip mentioned, the hood offers protection from bumps and bangs as well as inadvertent touches.
Ronald ­ S. ­ Jr.
Gallery: 12 photos
Nov 14, 2006 01:04 |  #13
Stray light not only can produce flare, but it can throw off your exposure in, for example, AV mode. If stray light gets into the lens, but that light is not reflected off your subject, you will most likely get an underexposed image. The hood blocks this light, which is what you want. You only want to see the light on and near your subject. As Dan said, it will have a negative impact on your image otherwise.
AeroSmith
Gallery: 46 photos
Joined Feb 2006
Nov 14, 2006 06:29 as a reply to  @ Ronald S. Jr.'s post |  #14
Always used the Canon hood on my 85/1.8....same good fits the 100/2. Can't comment on flare without the hood. But I've used the lens extensively outdoors with the hood and a UV filter and have never experienced any noticable flare.
Josh Smith
SuzyView
Nov 14, 2006 06:38 |  #15
The hood is tricky to put on and take off. I dropped it a couple of times already and one time, it went sailing across the room.:o
1,759 views & 0 likes for this thread, 13 members have posted to it.
2808 guests, 137 members online
