I was reading reviews and I heard the G5 doesn't come with a charger. Is this true? If so, where would I buy a charger if I were to buy the camera?
ALarsh Member 34 posts Joined Jan 2004 More info | Jan 25, 2004 19:30 | #1 I was reading reviews and I heard the G5 doesn't come with a charger. Is this true? If so, where would I buy a charger if I were to buy the camera?
civis Member 235 posts Joined Sep 2003 Location: Midwest USA More info | Jan 25, 2004 19:33 | #2 It comes with an AC adapter, which also serves to charge the battery in-camera.
Jan 25, 2004 19:38 | #3 Thanks for your help!
Claytonian Member 192 posts Joined May 2002 Location: Wisconsin More info | Jan 26, 2004 09:05 | #4 An external charger is much more convenient than charging in-camera, though. Some would argue it saves wear and tear in the camera as well. I have a Lenmar Mach1 speed charger which charges the battery in 30 minutes. This would be even more beneficial if you only have one battery to start with. Then when you get two, you can easily switch out the dead one and it will be ready for you before the second even gets close to being run low. Enjoy your G5 if you end up getting it.
Jan 26, 2004 15:49 | #5 Claytonian wrote: An external charger is much more convenient than charging in-camera, though. Some would argue it saves wear and tear in the camera as well. I have a Lenmar Mach1 speed charger which charges the battery in 30 minutes. This would be even more beneficial if you only have one battery to start with. Then when you get two, you can easily switch out the dead one and it will be ready for you before the second even gets close to being run low. Enjoy your G5 if you end up getting it. How much does it cost and where did you get it?
Claytonian Member 192 posts Joined May 2002 Location: Wisconsin More info | Jan 27, 2004 08:29 | #6 I got my charger from Buy.com. It was about $60 at the time. Looks like they have a new model listed now and it is $70.
| Latest registered member is semonsters 1480 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
