Thread started 13 Nov 2006 (Monday) 16:24
300 F2.8 & 2X teleconverter or 600
canonshooter4life
Nov 13, 2006 16:24 |  #1
If you cant afford the 600 how does the 300 with TC compare i know it will be slower but how much worse will image quality be???
Brandon
Brandon
Gear: Canon 60D, Canon 400mm f5.6L, Nifty Fifty, Canon 580EX, Kenko tube set, Kenko Pro 1.4X TC (coming next), Bushhawk, Manfrotto 055 ProB, and Manfrotto 322 grip head.
coreypolis
Nov 13, 2006 16:30 |  #2
it won't be awful, but you will really need good light. A big bright viewfinder from a 1 series or 5d would really help too.
AF rather than IQ tends to be the biggest challenge
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
Billginthekeys
Billy the kid
Joined Nov 2005
Nov 13, 2006 16:32 |  #3
the 300 2.8 with the 2x gives good results, actually quite great results. but shots from the 600 F4 are stunning.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
pparker
Nov 13, 2006 16:32 |  #4
I guess it depends on what camera body you use and the type of work you do. The 300 2.8 is a stellar lens that works well with the TC's.
If you are using any camera body other than the 1 Series, you will not be able to use autofocus with the 2 X Teleconverter.
If Wildlife and Bird work is one your agenda, I'd go with the 600 mm. I have the 600 f4 and really want the 300 2.8 as my second Super Telephoto.
Pete Parker from a three stoplight town in Texas
http://pparker.zenfoli​o.com/p610500614/ (external link)
Billginthekeys
Billy the kid
Joined Nov 2005
Nov 13, 2006 16:34 |  #5
pparker wrote in post #2257826 (external link)
completely false. the 300 2.8 will autofocus with the 2x on any DSLR because it is only 5.6 with the 2x on. on the 1series it can still autofocus with both TCs stacked
Mr. the Kid.
Go Canes!
canonshooter4life
Nov 13, 2006 16:36 |  #6
yeah but i just might be able to afford the 300 f2.8 but the 600 f4 will never be mine... cory why would AF be the biggest problem my 400 f5.6 focuses just fine at 5.6 wouldnt the 2.8 and a 2X TC be essentially f5.6?? and if im right the IS will still work with the TC??
Brandon
Brandon
gasrocks
Nov 13, 2006 16:37 |  #7
Yes, the IS will still work even with TC's. But, you know the rule is to not buy a lens when you are planning on only using it with TC's. Do you need a 300/2.8 for other things?
Billginthekeys
Billy the kid
Joined Nov 2005
Nov 13, 2006 17:06 |  #8
canonshooter4life wrote in post #2257846 (external link)
Brandon
unless you NEED a 300 2.8 for something in that case i would suggest you go for the 500 F4. much better for birds and nature than the 300 2.8, and much more bugetarily feasible than the 600 F4
Mr. the Kid.
Go Canes!
coreypolis
Nov 13, 2006 17:13 |  #9
the TC's and AF aren't best friends. the 1.4x if it is enough reach solves a lot more problems than the 2x creates.
canonshooter4life
Nov 13, 2006 17:25 |  #10
Well i guesse i would only be using it with the TC unless i can get really close to the bird the 500 would be better...then with a 1.4 TC i would have a 700 f5.6 lense with IS but the 500 would probably be fine in most situations(better start saving and lifting weights:lol: )... does the 1.4 give better image quality then the 2X??
Brandon
Brandon
canonshooter4life
Nov 13, 2006 17:38 |  #11
I just looked at the prices and i think it would be better to go with the 300 f2.8 the 500 is 2500 more when all is done with taxes... so i guesse i will have to think about this one...
Brandon
Brandon
gasrocks
Nov 13, 2006 19:32 |  #12
What is the longest lens you have now?
coreypolis
Nov 13, 2006 19:36 |  #13
the 1.4x is considerably better than the 2, Q wise. there is little to no difference on the 300 with teh 1.4, but it will definetly be noticeable, though not unuseable with the 2x
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Nov 13, 2006 19:46 |  #14
Billginthekeys wrote in post #2257825 (external link)
I don't have the 600, but I have the 300/2.8 & 400/2.8. Both are stunning lenses, and I would expect stunning results also from the 500/4 and 600/4. I know that the 300/2.8 works very well with the 2X teleconverter, as does the 400. But, there is a bit of a loss in IQ with the 2X. I would say that the 300 + 2X is very good, while the 600 is excellent.
Tom
5D IV, M5, RP, & various lenses
canonshooter4life
Nov 13, 2006 19:50 |  #15
my longest is the 400 f5.6 but is only good in sunny days or with monopod...but it is still as slow as my 75-300...now im thinking i dont need longer and the 300 would be good for low light and it has IS and can be a 420 mm with the 1.4 TC F4...now im thinking to go with the 300 it is less money and more versatile in my opinion... what do you guys think??
Brandon
Brandon
2,513 views & 0 likes for this thread, 11 members have posted to it.
2892 guests, 133 members online
