Thread started 13 Nov 2006 (Monday) 18:20
YEARG! Foiled by F/2.0
aacmckay
Nov 13, 2006 18:20 |  #1
Shot some pictures of my girlfriend putting her makeup on before our anniversary dinner this weekend. Wanted to get some cute shots. Decided the Nifty-50 was the lens of choice. Apparently I need more practice with it. I was foiled by f/2.0. I got her cheek in focus, but her eye is terribly OOF. Must remember DOF chart for nifty! :P
I really do like what I was going for in this shot. It's just too bad I blew it. :(
IMAGE: http://www.photoniceye.ca/photography-on-the.net/Foiled_by_f2.jpg
Andrew
Canon 20D
Canon Elan 7E
Kit lens, EF 28-135mm USM IS, EF 70-300mm USM, EF 50mm F/1.8
Manfrotto 190CL Tripod with 141RC Head
580EX Speedlite
Hellashot
Joined Sep 2004
Nov 13, 2006 18:23 |  #2
Sounds like your lens mis-focused - not the shallow DOF threw your shot off. Did you focus on her eye?
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
cdifoto
Don't get pissy with me
Nov 13, 2006 18:23 |  #3
soften up the cheek and pretend its glamour... :)
I almost always shoot with flash indoors for the DOF reasons. I just don't like having eye in nose out, etc.
aacmckay
Nov 13, 2006 18:35 |  #4
Hellashot wrote in post #2258276 (external link)
Well take a look at a 100% crop of the cheek and eye:
IMAGE: http://www.photoniceye.ca/photography-on-the.net/amanda_cheek_100percent.jpg
Looks like the cheek is okay (not perfect) to me. Sharper than the eye judging by the texture. I just calculate the DOF as being about 4.2 inches considering the distance I was. Maybe the lens front focused a bit. But I'd consider this shot a "user error".
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
aacmckay
Nov 13, 2006 18:41 |  #5
cdi-ink.com wrote in post #2258277 (external link)
Funny, I was thinking pretty much the same thing
Yeah I do too, but I was trying for some moody light. I didn't want to over power the lighting in the bathroom. Guess I coulda bounced the flash. Oh well, add that to the "lessons learned" list. :)
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
cdifoto
Nov 13, 2006 18:43 |  #6
I try moody light every so often. It rarely works cuz I can't focus for snot or I don't get shutter speeds I need. lol.
aacmckay
Nov 13, 2006 18:46 |  #7
Forgot to answer that...
No I didn't focus recompose. I should have. I was on center focus point and it's right on her cheek where the shot is the most in focus....
I really want to upgrade cameras so I can use the * button to focus. Separate metering and focusing. Oh well, can't always blame the equipment right? Gotta make due with what you have. :D
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
aacmckay
Nov 13, 2006 18:46 |  #8
cdi-ink.com wrote in post #2258351 (external link)
Same here, but I try and try again for the practice, and sometimes I do get it right. :)
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
cdifoto
Nov 13, 2006 18:48 |  #9
Focus-recompose would most likely have turned out even worse results than this. Working with narrow DOF almost dictates that you use the focus point right over the area you want in focus. Recomposing throws it off too much unless you're lucky.
aacmckay
Nov 13, 2006 18:51 |  #10
cdi-ink.com wrote in post #2258362 (external link)
Hmm, true enough, I think I've had that happen too. Well upgrading would give me more focus points to select though. Gotta be nice having more than 7.
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
pagefile
Nov 13, 2006 18:52 |  #11
That is what I have learned here on POTN, focus on the eye that is closes to you. Then recompose the shot if needed. I used to just focus on the face, anywhere. I've learned on POTN that its the eyes that need to be infocus to make a good shot.
BTW: Did she get mad at you for posting her... uummm... prep time to be scrutinized?
My Gear>>
"It is better to solve the right problem the wrong way than to solve the wrong problem the right way.”
Richard Wesley Hamming
aacmckay
Nov 13, 2006 18:57 |  #12
pagefile wrote in post #2258380 (external link)
Yes I know it's important to have eyes in focus. The issue being not always being able to get eyes on a focus point, and as cdi-ink.com mentioned. Not being able to focus recompose with narrow DOF.
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
pagefile
Nov 13, 2006 20:11 |  #13
aacmckay wrote in post #2258403 (external link)
I was not taking a shot at you. I was stating what I have learned on POTN and that it now makes my images look much better.
My Gear>>
aacmckay
Nov 13, 2006 20:14 |  #14
pagefile wrote in post #2258671 (external link)
No problem. :) Sorry, didn't mean to come across like I as offended. I wasn't. ;)
Andrew
Canon 20D
Canon Elan 7E
580EX Speedlite
pagefile
Nov 13, 2006 20:31 |  #15
aacmckay wrote in post #2258689 (external link)
Ok all is good there.
This is whats helping me. I dont know if this would have worked with out the uses of your flash.
I have found that if I set the dial to M then set exposure at 125 or 160 and set the aperture to 5.6. I am getting great shots, but that is with a flash.
Now if I was to do it without a flash, I would lower the exposure to maybe between 5 and 15.
I don't know if that will help you or not, hope it will some. You may know all this already.
My Gear>>
2,470 views & 0 likes for this thread, 5 members have posted to it.
2764 guests, 142 members online
