Thread started 14 Nov 2006 (Tuesday) 17:15
"Wet" cleaning sensor
pttenn
Nov 14, 2006 17:15 |  #1
OK-I tried the blowing out on the sensor per directions in my Canon book. I have spots on pictures in the sky-thought it was either my new 400 lens or new 1.4 extender, but tried both lenses separately and together and still have spots. Must be the Camera. (20D) So how do you Wet Clean the sensor? If this is somethng I can do I don't want to take it to Wolf Camera they overcharge for everything!
Karen
coreypolis
Nov 14, 2006 17:16 |  #2
google eclipse solution. you use that with a sensor swab and you're good to go
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
pttenn
Nov 14, 2006 17:21 |  #3
Thanks..I will look under Google next. Where to buy a sensor swab????
erdavis
Nov 14, 2006 18:21 as a reply to  @ pttenn's post |  #4
Try the Copperhill cleaning kit. You can find it at the following address. http://www.copperhilli​mages.com/index.php?pr​=products (external link)
I used it and it took care of sensor dust on my 20D the first time. It arived in two days via UPS.
E.R.Davis,
Canon EOS C70, Canon RF 24-70 f2.8 IS, Azden SGM-250 Mic
Panasonic Lumix S5, Sigma 16-28mm 2.8, Sigma 45mm 2.8, Sigma 105 macro
iPhone XS Max, Beastgrip Pro, Beastgrip 0.43x extreme wide angle lens with Macro, Beastgrip 1.33x Anamorphic lens.
pttenn
Nov 14, 2006 18:39 |  #5
erdavis wrote in post #2263329 (external link)
Thanks for the info. Will look it up.
Karen
pttenn
Nov 14, 2006 20:16 |  #6
Hey that's a cool site and I ordered a kit to get started. But enjoyed reading the whole thing and looking at his gallery. I even sent the site to someone else. I like that guy! Thanks for the link.
Karen
indpndnt
Joined Jan 2005
Nov 14, 2006 20:26 as a reply to  @ pttenn's post |  #7
They're super quick on delivery. The kit is a great resource. You've made a good purchase.
Laffctx
Nov 14, 2006 20:32 as a reply to  @ indpndnt's post |  #8
I second Copperhill.........tha​t is the ticket for sure!!!!!!!!!!!!!
jev
Joined Jun 2005
Nov 15, 2006 19:55 |  #9
yes Copperhill gies excelent results
5d, 350D, Canon 50mm f/1.8, Peleng 8mm, Canon 70-200 f/2.8L IS, Canon 24-70 L, Canon Speedlite 430EX
Jev
http://blog.artq.com (external link)
http://artq.smugmug.co​m/ (external link)
Sloany
Nov 16, 2006 07:45 |  #10
You can also go to CVS and look in the womens eye makeup section for the small -White- Nylon Bristle Brushes. They are tapered and about 5/16 in. wide x 3 in.long. They are un coated and super clean. They come in a zip lok style bag, for about $2.25 Use canned air to charge them before using them, gently brush the sensor, along with using a blower. They use the same White Nylon as the $ 30.00 white nylon brushes that are sold as sensor cleaning brushes. You can also find good quality artist brushes made of the same tapered white nylon " with no sizing on them " in various widths that are perfectly safe for sensor cleaning. Just be careful not to saturate the top of the sensor with cleaning solution to the point where the liquid may migrate under the filter on the sensor. A little goes a long way.
Good luck. Ken
Hermeto
Nov 16, 2006 09:10 as a reply to  @ Sloany's post |  #11
Sloany, I am not sure if I understood correctly, do you suggest using nylon BRUSH for WET sensor cleaning?
Sloany
Nov 20, 2006 19:32 |  #12
You can actuall y use them both ways. But use it dry at first. That will remove any dust. If you have a glob of something sticking to the filter that covers most all sensors, you can try moistinig the brush and try to dislodge the crud. DO NOT FLOOD THE FILTER OVER THE SENSOR WITH THE CLEANER OR ANYOTHER SOLUTION !!!!!!!!! This what the manufactures are mostly concerned about when using the wet method of cleaning. PEOPLE HAVE FLOODED THE TOP OF THE SENSOR AND LIQUID GETS BETWEEN THE FILTER AND THE TOP OF THE SENSOR. Just take your time and you will do fine. Make sure you have a fresh battery in the camera to keep the mirror locked up while you doing the cleaning. It may take a few tries, be patient.
good luck Ken S.
cgratti
Lord_Malone, your still a newb...
Joined Feb 2004
Nov 20, 2006 20:43 |  #13
Eclipse Solution and Pec pads. Very simple process, just be very careful and you will have no problems.
Here is a decent tutorial, I suggest you read it first and then try it.
http://www.copperhilli​mages.com/index.php?pr​=Tutorials1 (external link)
Canon 30D
Canon 10D
Canon 28-105 f/3.5-4.5 II USM
Apple iMac G5
2,357 views & 0 likes for this thread, 9 members have posted to it.
2260 guests, 126 members online
