The exif data is all of the info attached to that photo. It will include things such as shutter speed, f-stop, lens used, iso, among others. From the looks of it, you probably shot at too slow of a shutter speed. The basic rule of thumb for avoiding camera shake is 1/focal length of the lens. So, with your 50 it would be 1/50 of a second shutter speed to avoid blur. That rule of thumb is a carryover from film, and for digital it is usually wise to figure in the crop factor of your camera also. With the 1.6 crop factor on your XTi, your 50mm lens is essentially now a 80mm lens, so your minimum hand-held shutter speed should be somewhere around 1/80 of a second. To achieve that, you'll need to either increase your iso, or open up your lens some (use lower f number)
