Hi all,
I am buying some lenses soon the biggest being 70-200 2.8L IS.
My body is a 30D, will i need a grip to be able to use it comfortably?
What about a Monopod would that also be necessary?
RgB Goldmember 1,323 posts Joined Aug 2006 Location: Sydney, Australia More info | Nov 15, 2006 02:07 | #1 Hi all, Daniel Speranza
pup Goldmember 1,812 posts Joined Mar 2006 Location: NJ More info | Nov 15, 2006 02:16 | #2 I have a 30D Screening shots
joegolf68 Goldmember 3,269 posts Likes: 1 Joined Nov 2005 Location: Sacramento CA area More info | Nov 15, 2006 02:52 | #3 I am still on the search for a monopod. Got top get out and actually test them, but I think a good monopod would be invaluable. My tripod weighs like a ton and is so limited as to where to take and all, a real hassle compared to a monopod, IMHO. Gear List
kram obvious its pointless 2,612 posts Likes: 3 Joined Feb 2005 More info | Nov 15, 2006 02:57 | #4 The 70-200L IS is quite a heavy lens - a monopod would be a very good idea. Not sure if the grip is a factor based on the lens - it just seems to be an accessory that some cant live without and some other cant seem to care about Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
StealthLude Goldmember 3,680 posts Joined Dec 2005 More info | Nov 15, 2006 03:05 | #5 monopod is a must... I got one about 3-4 days ago, and now it stays in my trunk. [[Gear List]]
Kennymc Goldmember 1,501 posts Joined May 2003 Location: N.E coast of UK More info | I feel the grip will be advisable as it seems to balance longer, heavier lenses better when hand held... Use the collar on the lens to attach it to the monopod by a quick release plate, not the grip... www.kennymc.com
grego Cream of the Crop 8,819 posts Likes: 2 Joined May 2005 Location: UCLA More info | Nov 15, 2006 03:33 | #7 I've used the 70-200 2.8 IS with a monopod. Nothing wrong with that. It works better for some applications with the monopod actually, even in more than enough light. It gives a good balance and helps you stabilize yourself. Go UCLA
Nov 15, 2006 04:52 | #8 The Opteca grip do they make one to fit the 30D or have they done the same thing as Canon and haven't bothered making one to fit the 30D and just use the 20D's Daniel Speranza
SteveBeck Goldmember 2,503 posts Joined Oct 2006 Location: Greenville, SC More info | Monpods are a must have in the gear bag. But depending opn what you are shooting dictates the usage of the monopod and how good you are at hand holding. From what little experince I have shooting the AMA Superbike Race at Road Atlanta I shot the first part of the first day with a monopod and it became real cumbersome for me to pan smoothly witht he bikes. I ended up shooting hand held with my 70-200 f2.8 is lens the rest of the day and weekend. It really is not that heavy of a lens, I held and shot for about 10 hours each day. Gear List? My gear is bigger than yours? Just shoot have fun...
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Nov 15, 2006 07:18 | #10 I needed a grip for my XT + 70-200 but I don't feel the need so much for my 30D. It's only during extensive portrait orientation shooting that I kinda wish I had the grip. I have a monopod but almost never use it. Did you lose Digital Photo Professional (DPP)? Get it here
Andy_T Compensating for his small ... sensor 9,860 posts Likes: 5 Joined Jan 2003 Location: Hannover Germany More info | Nov 15, 2006 07:22 | #11 I have been using my old 80-200/2.8L (same size, but a bit lighter than the 70-200/2.8L) on my 20D now for quite some time without either a grip or a monopod, and it feels ok ... especially if you take the camera/lens combo by the lens barrel, it has a very nice weight distribution. some cameras, some lenses,
LarryWeinman Goldmember 1,438 posts Likes: 66 Joined Jul 2006 More info | Nov 15, 2006 07:33 | #12 A grip will help alleviate the feeling of front heavy lenses but one of the main advantages besides extended battery power is the ability to keep your elbows in at your body when shooting vertical giving you much greater camera steadiness. 7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Nov 15, 2006 07:39 | #13 Larry Weinman wrote in post #2265890 A grip will help alleviate the feeling of front heavy lenses but one of the main advantages besides extended battery power is the ability to keep your elbows in at your body when shooting vertical giving you much greater camera steadiness. A lens is only front heavy if you're holding the entire rig improperly. Did you lose Digital Photo Professional (DPP)? Get it here
Nov 15, 2006 07:51 | #14 cdi-ink.com wrote in post #2265918 A lens is only front heavy if you're holding the entire rig improperly. Please advise how to hold a "front heavy" lens? Joe
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Nov 15, 2006 07:56 | #15 Bosman wrote in post #2265953 Please advise how to hold a "front heavy" lens? I'm serious, I had the Tamron 28-75 2.8 on my Rebel XT and returned it, cause I was used to only having the kit lens or the 50 1.8 which are extremely light. I have bought another Tamron 28-75, and I know it isn't heavy, but there is a huge difference between it and the two I'm used to. Really want to learn proper handholding technique. I have taken many shots with my 50 1.8 at very, very slow shutter speeds and have not a camera shake problem, but not as much success with the Tamron as yet. Support the lens with your left hand...instead of trying to hold it all from the camera body. The right hand should only be operating controls, not carrying a load. Of course when there's a really small lens on the front you kinda have to balance it all together with both hands. Did you lose Digital Photo Professional (DPP)? Get it here
| Latest registered member was a spammer, and banned as such! 2881 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
