Hello everyone,
I have a 350D w/ kit lens, UV filter and lens hood. Recently, I took some shots alongside a busy street in my town at night. I wanted to capture a flourescent sign in the upper right of the shot and the blur of the passing cars through the middle of the pic. I used a tripod w/ the above set-up. I seemed to have captured some lens flare in the center of the black night sky section of the shot. It's a small, half-moon shaped yellow/gold spot. The info on the shot is as follows: F/5.6; shutter 1"6; 100 ISO; manual @ 25mm. Also, the WB was set to flourescent. Is this a case of a problems with the lights in the scene or any light off to the side of where I was shooting? The glass was clear as was the UV filter. With the inexpensive glass on the kit lense, is that a cause for such a problem? Will better glass take care of this? PS makes it pretty easy to take this glitch out. I know an answer is hard to decifer w/out the shot itself but it's too large to upload for this post. Thanks for any and all thoughts. Sincerely, Joe.
