Thread started 16 Nov 2006 (Thursday) 07:45
Lens shadows
hawk911
Nov 16, 2006 07:45 |  #1
Just got my Sigma 24-70 f2.8 and took a few pictures with just the camera flash. I also have a camera-mounted 550ex, but with the camera flash there's a shadow when shooting at 24mm. How do you get around that, or don't you? The shadow seems more prevalent in close shots- subject less than 10 ft away.
BTW- love the site. Lots for me to learn.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
Dazecoop
Nov 16, 2006 07:51 |  #2
If your using your built-on flash rather than your 550ex, you'll probably find the shadow is created because the lens is so massive :) The built in flash will get in the way.
If your using your 550ex, then try learning and playing with bouncing the flash off of walls and ceilings. It creates a much more natural lighting effect without any harsh shadows.
JimAskew
Gallery: 6 photos
Nov 16, 2006 07:57 as a reply to  @ Dazecoop's post |  #3
Hi,
I have the same problem with my Canon 10-22MM EF-S. It shows up between 10MM and 17MM. I have no shadow problems with 580EX flash unit.
This is just another "lesson learned" to keep tucked away in the back of your mind when using that particular lens. :)
Jim -- I keep the Leica D-Lux 7 in the Glove Box just in case!
7D, G5X, 10-22MM EF-S, 17-55MM f/2.8 EF-S IS, 24-105MM f/4 EF L, Leica D-Lux 7
hawk911
Nov 16, 2006 08:12 |  #4
The 550 gets up high enough that no shadows are cast. I'm learning the nuances of bounce and direct usage. I took an intro class to flash photography, but the instructor didn't even scratch the surface of proper usage.
Dazecoop
Nov 16, 2006 08:42 |  #5
Below are a couple of links to flash photography that I tried a while back. This was my first attempt at using my flash (430ex bounced)
http://flickr.com/phot​os/dazecoop/291010898/ (external link)
http://flickr.com/phot​os/dazecoop/291010405/ (external link)
I still believe that practicing and messing about is the quickest way to learn.
WMS
"Escargot on the Hoof"
Nov 16, 2006 08:48 as a reply to  @ Dazecoop's post |  #6
In addition to bouncing the flash from ceilings or walls you could use a flash bracket and hot shoe cord to have a greater distance between the camera lens and the flash.
WayneM
I'm just a simple maker of love charms and tokens,who occasionally takes a picture or two.
Gear list: more toys than I need, Fewer than I want.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Nov 16, 2006 08:53 |  #7
hawk911 wrote in post #2271190 (external link)
With my 24-70 I can see the the shadow from the lens hood if I use the on camera flash. I really wish it was not there. Canon could have put the effort into something more useful to us that the useless on camera flash.
Doc Klepper in the USA
I
791 views & 0 likes for this thread, 5 members have posted to it.
Lens shadows
2881 guests, 133 members online
