drisley wrote in post #2274706
Well, i tried Rocket Blower, compressed air, sensor brush, and a quick attempt with the copperhill... none of these dust bunnies even budged an inch!!!
Drisley: I would suggest that you repeat the Copperhill process a few times. I haven't read it for a few weeks, but I seem to recall that he recommended repeated gentle cleanings until it came clean.
And, perhaps a wee spot of the cleaner is worth a try to "dissolve" a stubborn spot. But I'd be very careful about this as who knows where the liquid might run?
Further to my comments on the rocket blower vs the compressed air - I realize that the purpose isn't to "replace the air" in the camera, the purpose is to blow the dust particles out. If dust is truly the problem, then using ambient air (room air) that is full of dust particles may not be the solution. We do realize that air is full of dust particles unless it has been filtered.
What it may come down to is that what we call dust on the sensor is not really dust. I suspect that it consists of small particles that wear off the camera when the mechanical parts operate - such as the mirror and the shutter.
Now that my camera has 3,000 shots on it, I'm having far less trouble with "sensor spots" than when it was new. This might be attributed to two things: 1) the initial "break-in period" is over, OR, 2) there was a lot of "stuff" in the chamber from the manufacturing process, and it has loosened/dislodged and been blown out with repeated cleanings.
