Thread started 17 Nov 2006 (Friday) 10:51
70-200L 4f test @ Camera Store
bufferbure1
Nov 17, 2006 10:51 |  #1
Hi gangs,
I thought I would share some test photos at taken during my last trip to a camera. I was trying out the EF 70-200 F4 and had some issues with WB:
http://www.flickr.com …721575943800992​70/detail/ (external link)
In general, I had issues with WB on 70-200F4 at 200mm shooting at a flourscent light sign. AWB works sometimes and after switching to Flourscent light preset, WB still not very accurate or reliable at all.
However, 70-300IS and 100-400L did not encounter this WB issue.
The salesman was clueless too, nothing against him tho, he is a very knowledgable guy.
I also tried 70-300IS and 100-400 to compare their color contrast. Nothing scientific.
Comments?
"I collect pictures, not gears..."
Lenscode:1635.1785.50f​18.100Macro.70200F4IS.​580EX.30D.5D2
SoundsGood
Nov 17, 2006 11:37 |  #2
bufferbure1 wrote in post #2276331 (external link)
I was trying out the EF 70-200 F4...
I also tried 70-300IS...
Which of the two did you prefer?
40D and a whole bunch of lenses
Canon 430EX, Kenko 1.4x, Domke F-3X, F-5XB, Zeikos grip
Zenfolio Discount Code: YGK-8U7-1GG (external link)
laimis.s
Nov 17, 2006 11:40 |  #3
i did the same and tested the 70-200mm F4L in my local camera shop... i loved it but i must say i wasnt quite used to the focal length. at 200mm every movement was like OOOOHH cant keep it steady ^_^ but the images didnt blur, and that was at 1/60th...
Canon 5D, Mamiya RB-67, Wolf 5x4.
:: http://www.laimonas.co​.uk (external link) ::
:: http://laimonas-stasiulis.deviantart.c​om (external link) ::
bufferbure1
Nov 17, 2006 12:21 |  #4
SoundsGood wrote in post #2276498 (external link)
My take:
70-300IS: more value, more possibility, more photos period, IS will yield lower ISO noise in photos if handheld. Solid build and feel
Cons: no hood, zoom extends (but makes it compact)
70-200L f4: more quality, both in built and in sharpness, better for cropping, contrast about the same as IS to me), 67mm Yeah(same as 17-85IS)!!. A little faster AF & constant F4.
Cons: Require more skill to handle. Weird WB issue with the store copy, $another $3XX for the 1.4x tele converter in the near future
Both lens cost about the same in Canada after the hood factor on 70-300IS
Easier said than to decide.
SoundsGood
Nov 17, 2006 13:13 |  #5
bufferbure1 wrote in post #2276646 (external link)
Again... which one did you prefer? :)
bufferbure1
Nov 17, 2006 13:59 |  #6
SoundsGood wrote in post #2276836 (external link)
I will tell you after I've bought it :)
Seriously, F4 is in the lead at this moment. I don't think I could go wrong with either choice though.
Roy ­ Hernandez
Nov 17, 2006 14:34 |  #7
hhmm... i think its not the WB issue on the test that you made... looks like the metering is off.
For visiting San Diego area info @ - http://www.sdphotoforu​m.com (external link)
My Photos (external link) - I'm 1OO% FILIPINO! I eat Balot, Bagoong, and Tuyo. Ikaw Ba?!
morehtml
Nov 17, 2006 14:37 |  #8
I thought the camera controls white balance and not the lens.
"Allen's Visions of Nature Gallery" (external link)
www.allensvisions.com (external link)
more glass than I need
bufferbure1
Nov 17, 2006 15:09 |  #9
NIKONUSER wrote in post #2277145 (external link)
Could be. It only happened on the 70-200 F4 @ 200mm. Metering is done thru the lens correct?
steved110
Nov 17, 2006 16:46 as a reply to  @ bufferbure1's post |  #10
White balance is done by the camera, not the lens. fluorescent lighting is notoriously difficult as each tube has its own particular 'white balance' and these can change constantly even out the same tube. That's probably why you noticed the problem only with the one lens.
the only way to resolve the issue is to set custom white balance or set the white balance in PP if you shoot RAW
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
ggw2000
Nov 17, 2006 18:23 |  #11
steved110 wrote in post #2277792 (external link)
Exactly right! I will go on to say that Canon Camera are poor under flourescent lighting in general- know fact. If you would have switched to "kelvin" and set it to 2900 degrees your pics would have come out much better. This is without flash of course. With flash set to "flash".
The F4 is a super lens and very sharp/contrasty/ and has excellent saturation.
Gerry
braduardo
Nov 17, 2006 18:29 |  #12
The 70-200mm f4 L is as sharp as you could imagine... Yup, that sharp!
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
1,998 views & 0 likes for this thread, 8 members have posted to it.
961 guests, 138 members online
