Thread started 17 Nov 2006 (Friday) 21:28
QUESTION: Sigma 180mm Macro lens
cjm
Gallery: 11 photos
Nov 17, 2006 21:28 |  #1
I am thinking of getting a macro lens and am sort of thinking the Sigma 180mm might be for me. From what I read on the specs of the Sigma Vs The Canon is that these are almost identical so I am wondering if I should bother spending the extra $600ish dollars on the L version or just get a 180mm Macro.
Anyone here ever owned both? Looking for some of the expert help on this one. Thanks.
(Also anyone have the Sigma 180mm Macro for sale, let me know)
Christopher J. Martin
imagesbychristopher.co​m (external link)
LightRules
Return of the Jedi
Joined Jun 2005
Nov 17, 2006 22:12 |  #2
I've never used it, but most (if not all) who own it rave about it. Or, there's also the excellent 150 f2.8 EX Macro.
Larry ­ Weinman
Nov 18, 2006 08:20 |  #3
I have owned both. The Sigma 180 is a very good lens, the Canon is better both for color and sharpness. Is it $600 better, I can't really answer that for you but it is for me. As for the Sigma 150mm macro mentioned by lightrules, it is also a very good sharp lens but it only goes to f22 and this could produce depth of field problems in very close work. Nobody knows why Sigma did this. A good long focal length macro will go to f 32
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Nov 18, 2006 09:58 |  #4
I have only ever seen one macro distance review of macro lenses, my memory is the Sigma was not so good wide open and the Canon was generally better.
http://translate.googl​e.com …-8&prev=%2Flanguage_too​ls (external link)
Macrophotography by LordV
LightRules
Return of the Jedi
Joined Jun 2005
Nov 18, 2006 10:00 |  #5
Klaus did a fine review here http://www.photozone.d​e …es/sigma_180_35​/index.htm (external link)
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 18, 2006 10:50 |  #6
LightRules wrote in post #2280545 (external link)
Doesn't tell you much about performance at closeup distance where the aberations are likely to be very different however.
LightRules
Return of the Jedi
Joined Jun 2005
Nov 18, 2006 11:03 |  #7
Lester Wareham wrote in post #2280712 (external link)
Frankly, I've never heard a complaint about its close up performance (especially since it was designed for this kind of work). Here are a few more reviews for the OP, at least for more reading on this lens option:
http://www.shutterbug.​net/test_reports/0601s​b_sigma/ (external link)
http://www.juzaphoto.c​om …ma_180mm_macro_​review.htm (external link)
http://www.fredmiranda​.com …=135&sort=7&cat​=38&page=1 (external link)
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 18, 2006 12:29 |  #8
LightRules wrote in post #2280747 (external link)
Just pointing out that IMATEST measurements don't tell you much about the close focus performance of a lens.
As I say I know of only one extensive comparative macro range test (http://translate.googl​e.com/translat...langu​age_tools (external link)) and the Sigma did not look the good against Canon but it is quite a bit cheaper.
Of course its just one test, but the problem with most online reviews is they are just owner testimonials, or in some cases like most magazine test, where they try it out but don't do comparative IQ with other products.
That is the advantage of photozone, excellent site. But it tells little about close focus performance. The low magnification test results may be an indication of life size performance but you just don't know.
illy
Nov 18, 2006 12:33 |  #9
Here's a good review I found:
But the looks of things the sharpest lens is the Canon MPE-65 then Tamron 180, Tamron 90, Sigma 50
600D, 17-50, 50, 60, 100, 70-200, 430EX
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 18, 2006 12:37 |  #10
illy wrote in post #2281023 (external link)
Like minds I see. ;-)a
CountryBoy
"Tired of Goldmember label"
Nov 18, 2006 12:37 |  #11
I don't think there is $600 worth of difference between the 2 . My choice will be between the Sigma 150 or 180mm.
Hi
illy
Nov 18, 2006 12:39 |  #12
Lester Wareham wrote in post #2281038 (external link)
Except yours doesn't work :D
Not Found
The requested URL /translat...language_t​ools was not found on this server.
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 18, 2006 12:42 |  #13
illy wrote in post #2281049 (external link)
Well the link does, the mind might be another matter. :p
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 18, 2006 12:45 |  #14
CountryBoy wrote in post #2281040 (external link)
The sigma 150 sounds like its better than the 180, a lot newer also. The 150 is 50% heavier than the stalwalt Canon 100mm but a bit more managable than either or the 180mm's (Canon or Sigma).
Unfortunatly the review I posted pre-dates the 150mm, but if you hunt around he has an update than includes it, however its not directly comparative.
PetKal
Nov 18, 2006 14:20 |  #15
Lester Wareham wrote in post #2281009 (external link)
Actually, I share a high regard in which PZ test results are generally being held. However, I also feel something must have gone awry with the IMA test of the 180L. At the focusing distances Klaus probably tested the lens, my 180L resolves better than any other lens I have with the possible exception of EF-60, EF 300 f/4 Non IS, and EF 17-55. Naturally, the 135L, 200 f/2.8 and 85's are in that general vicinity as well.
Potenza-Walore-Prestigio
2,495 views & 0 likes for this thread, 7 members have posted to it.
2622 guests, 154 members online
