My comments on the guy that damaged his sensor filter:
PT Barnum was said to have said (he actually didn't): There is a sucker born every minute.
My version: there are ten klutzes born every minute.
Think for a moment: Do we really know what "dust" is composed of? Is it lint dust from clothing, or dead skin? While these are yucky they are soft. Or is dust tiny pieces of clay sized dirt (which is rock, and very hard)?
BEFORE cleaning with the pad and solution, BLOW the surface off thoroughly. This type of dirt particle is far less likely to stick, so when the MOIST pad (not wet) is used GENTLY on the surface the grit won't grind into the surface. Common sense? I think so.
There will always be someone that won't or can't follow recommended procedures carefully and will screw something up.
Google for Copperhill, and read the article carefully and thoroughly. He doesn't have much use for a rocket blower (and neither do I - I use compressed "air"). But having said that, it is my opinion that gently blowing out the chamber and the surface of the sensor is a wise first step before the wet cleaning.
Think about it this way: if you were down on your hands and knees washing a floor, would you pick up and remove the large chunks of dirt and trash before using the water and cloth? Of course.
These are just my personal observations and opinions; I won't be insulted if anyone disagrees.
