Thread started 17 Nov 2006 (Friday) 22:40
Interpreting Histogram Information
TMR ­ Design
Joined Feb 2006
Nov 17, 2006 22:40 |  #1
I've gotten pretty good at using the histogram to determine correct exposures and making adjustments to reduce noise, etc..
Sometimes I notice that there is a chunk of the histogram that spikes and is at the top, completely flattened out, and at times this section can span 1 whole region (not sure what they are called) on the histogram. What does this indicate and what, if anything do you to to correct it?
Robert
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Nov 17, 2006 23:16 |  #2
It shows the ratios of light and dark, from white to black, in a bell curve format. this all depends on the data in the picture. Go here it is a nice job on this issue. http://www.naturescape​s.net/092004/gd0904.ht​m (external link)
Dante
I am not an Lcoholic. Lcoholics go to meetings!
Titus213
Nov 17, 2006 23:23 |  #3
I've been researching this to figure out how to say it and came up with one of my favorite sites: http://www.luminous-landscape.com …standing-histograms.shtml (external link)
Dante's site looks pretty good too. Basically you are looking at a graph indicating the distribution of luminance across the dynamic range. I think.:lol:
Dave
Perspiring photographer.
TMR ­ Design
Joined Feb 2006
Nov 18, 2006 19:19 as a reply to  @ Titus213's post |  #4
I do understand that and have read many of the links about histograms but I am still unclear about what it means when there is a chunk that is flattened at the top and the dynamic range is evenly distributed.
Robert
Titus213
Nov 19, 2006 00:39 |  #5
I would interpret it as meaning the majority of pixels in the image were concentrated in that zone of the exposure. Can you post and example with the picture?
Dave
Transportithere
Nov 19, 2006 00:45 as a reply to  @ Titus213's post |  #6
Information about the Histogram, Fantastic.
I always thought it used up battery and turned it off.
POTN is a wonderful source of information.
POTN has taken me around the world.
coreypolis
Nov 19, 2006 00:47 |  #7
Good tutorial
http://luminous-landscape.com …standing-histograms.shtml (external link)
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
Titus213
Nov 19, 2006 00:56 |  #8
Transportithere wrote in post #2283647 (external link)
You're kidding, right?
Dave
gkuenning
Joined Jan 2005
Nov 19, 2006 01:25 |  #9
A large range that is flattened at the top would indicate an area of the picture where there was a gradual and even transition from dark to light. For example, if you used a light that had a soft edge and placed the edge so that it illuminated a flat area, you'd get that kind of histogram. Another way to achieve that result would be to use a flash to light up a wall that was running almost directly away from you.
As long as the shot looks good, I wouldn't worry too much about it.
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
kevin_c
Nov 19, 2006 09:01 |  #10
Titus213 wrote in post #2283677 (external link)
I hope so.
Mind you, using it does use battery power :rolleyes:, ...along with autofocus and metering... :)
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
Glenn ­ NK
Nov 19, 2006 12:47 |  #11
gkuenning wrote in post #2283757 (external link)
I thought that a flat top on a histogram spike simply indicated that a lot of pixels captured information at that particular dynamic level, and that the information is there, but simply can't be charted on the limited vertical range of the histogram.
In the Luminous Landscape tutorial, there is a shot of the full moon - most of the picture area is very dark, and there is one chopped off spike at this dynamic level (near the left, but not totally black). Although most of the picture is dark, some detail can be seen - if the spike was jammed to the left, not much detail would be discernible.
When did voluptuous become voluminous?
TMR ­ Design
Joined Feb 2006
Nov 19, 2006 13:25 as a reply to  @ Glenn NK's post |  #12
For instance, here is a pic I took looking out a window and just working on metering and exposures.
What does the spike represent?
Robert
kevin_c
Nov 19, 2006 13:28 |  #13
TMR Design wrote in post #2285558 (external link)
I'd say that the middle 'spike' is the wall and the right hand 'spike' is the sky
-- K e v i n --
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Nov 19, 2006 13:36 |  #14
kevin_c wrote in post #2285567 (external link)
I would say exactly the same thing.
And there is simply too much data in the same tonal range for it all to fit on the histograms Y axis. Its my understanding that this dosn't matter, it has no effect on the image, and simply tells you that have a lot of data covering the same, or similar tonal range.
So long and thanks for all the flash
arthurgoh
Joined Feb 2006
Nov 19, 2006 13:53 as a reply to  @ Moppie's post |  #15
That's interesting. I guess that implies that the vertical axis (amount of pixels) is less than the total pixel count of the sensor, and therefore once a certain number of pixels with the same tonal range exceeds the axis the histogram peaks 'off the chart'.
I wonder if it's possible, or useful even, for cameras' onboard computers to dynamically scale the histogram so that all its pixels show on the chart even if the entire frame is filled with just one tone. Perhaps we can even experiment with different camera models with same sensor size to see if the max pixels on the vertical axis is constant.
5DmkII, 17-40f4, 24-70f2.8, 24-105f4IS, 70-200f2.8IS, 50f1.4, 85f1.2mkII, 100f2.8macro, 135f2
Gallery (external link)
2,310 views & 0 likes for this thread, 13 members have posted to it.
2258 guests, 125 members online
