Thread started 18 Nov 2006 (Saturday) 06:23
Nightime manual focus tips?
Axeman
Nov 18, 2006 06:23 |  #1
First time here, looks like a great forum. I have a Digital Rebel and was trying out some bulb shots the other night, but had trouble trying to get a good manual focus--using the small viewfinder image wasn't much help, since my eyes are lousy at night and were probably already adjusted to the dark. Setting to infinity doesnt help either, since some of the subject matter was closer up. Anyone have tips on how to get a good focused image in the dark?
Echo63
Nov 18, 2006 07:59 |  #2
use Cfn 4-1 and carry a small bright torch (flashlight for you americans)
turn light on to illuminate subject, press * button to focus
when subject is in focus, remove thumb from * button
turn light off, press shutter button
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
dougxt
Nov 18, 2006 13:38 |  #3
yep, flash light is the key. manually focus using the flashlight, then shoot.
I recommend using a remote at night.
http://www.dougjonesph​oto.com (external link)
50d, sigma 10-20mm, tamron 17-50mm, sigma 70-300, canon 50mm 1.8
SkipD
Joined Dec 2002
Nov 18, 2006 17:03 |  #4
You could go one step further and aim the flashlight/torch at the camera from the subject's position if it's fairly far from the camera, then focus on the bright spot of light.
Skip Douglas
Axeman
Nov 19, 2006 02:27 |  #5
Thanks for the suggestions, guys! i never would have thought of that--ill give it a shot (pun intended)
Transportithere
Nov 19, 2006 02:39 as a reply to  @ Axeman's post |  #6
I use a RC-5. But, you mentioned focus. Just keep on, keeping on.
The more you shoot at night. The more you will like it.
Just think fun and the better you will be.
POTN is a wonderful source of information.
POTN has taken me around the world.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Nov 19, 2006 09:16 |  #7
If there's room, you could put the light just out of the frame, but the same distance away & leave it there. Then just swing on it, half-press, swing back & take a 2nd pic.
DocFrankenstein
Joined Apr 2004
Nov 19, 2006 15:34 |  #8
Or you can use one of those little laser pens to focus on. Locks on instantly.
National Sarcasm Society. Like we need your support.
rhys
Dis-Membered
Nov 19, 2006 18:24 |  #9
Better than that... use an infra-red light source..
http://www.nvginc.com/​irlasdio.htm (external link)
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk (external link)
www.sageworld.org (external link)
www.sagephotoworld.com (external link)
Blog: http://360.yahoo.com/t​hunderintheheavens (external link)
Free cheese comes only in mousetraps
Transportithere
Nov 22, 2006 19:49 as a reply to  @ rhys's post |  #10
Great idea!!! I have not tried it yet.
Focus on the dot and instant focus..
tim
Light Bringer
Nov 22, 2006 20:03 |  #11
Eat more carrots.
DocFrankenstein
Joined Apr 2004
Nov 22, 2006 20:04 |  #12
rhys wrote in post #2286548 (external link)
But the drawback is that you won't be able to see the light source NOR the camera will be able to focus properly.
remember the IR mark on the lenses?
rhys
Dis-Membered
Nov 22, 2006 21:46 |  #13
DocFrankenstein wrote in post #2301288 (external link)
The STE2 uses IR for focus assist. All that does is shine a beam of IR light on command.
Rhys
DocFrankenstein
Joined Apr 2004
Nov 23, 2006 08:40 |  #14
rhys wrote in post #2301763 (external link)
I thought that it's not really IR cause you can still see the light.
If it's an IR laser, you won't be able to see it for sure simply because there's one wavelength with no "spill" to other frequencies.
rhys
Dis-Membered
Nov 23, 2006 10:53 |  #15
DocFrankenstein wrote in post #2303293 (external link)
It could well be near IR.
Hold a compact digital up in front of the IR beam with the LCD on and you'll be able to see the IR beam more easily.
Rhys
1,912 views & 0 likes for this thread, 9 members have posted to it.
1701 guests, 134 members online
