Thread started 19 Nov 2006 (Sunday) 12:46
how important is spot metering?-30DvsXTI
PixelChick78
Nov 19, 2006 12:46 |  #1
When comparing the XTI and the 30 D I found that there are very few differences between to two cameras. The only difference is the option for spot metering is not available with the XTi and the 30D has ISO 3200, oh and the 30d allows 5fps.
I think the 3fps the XTI offers is enough for me and the 3200 ISO on the 30D is probably hardly used (right?) so I am boiling it down to spot metering.
How important is spot metering to you and would you buy a camera without it?
Here is a comparison chart if you are interested:
http://www.dpreview.co​m …%2Ccanon_eos400​d&show=all (external link)
http://cestchicphoto.c​om (external link)
http://cestchicphotogr​aphy.blogspot.com/ (external link)
kevin_c
Nov 19, 2006 12:49 |  #2
The main difference for me would be the size of the XTi (400D) It is rather small compared to a 'normal' SLR/DSLR. I found it awkward to hold with my hands.
However, maybe that suits some people...
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
PixelChick78
Nov 19, 2006 12:52 as a reply to  @ kevin_c's post |  #3
I have small hands and I also suffer from right arm RSI (repetative strain injury) so the lighter smaller body is likely good for me too.
Glenn ­ NK
Nov 19, 2006 12:57 |  #4
PixelChick78 wrote in post #2285423 (external link)
I bought the 30D partly because it is heavy!! (piano player with good wrists and I like the heft).
I was attracted to spot metering (haven't used it yet, but maybe I will).
I was also attacted to 5 fps. I mainly shoot stills!!! What was I thinking?
I'm not a beginner (started in 1962), so it's not likely that I will suddenly start using these features (well I still like the weight).
In all likelihood, the 400/XTi will be perfect for you.
When did voluptuous become voluminous?
kevin_c
Nov 19, 2006 12:58 |  #5
Regarding the spot metering, I've only used the slightly inferior 'partial' metering on my 20D a couple of times and found it perfectly adequate for my needs, but it all depends on the situation and whether you think you need it really.
-- K e v i n --
adas
Joined Aug 2004
Nov 19, 2006 13:05 |  #6
For me this wasn't a deal breaker when I bought my 20D in june (wich actually doesn't have spot meter).
6D, 20D, G7X
Accentor
Nov 19, 2006 13:20 as a reply to  @ adas's post |  #7
I have the XTi (400D in Europe) and am very pleased with its performance. The small size suits my small hands, but I do prefer it with the battery grip.
Relevance of spot metering depends on what you are intending to shoot. I shoot mostly birds and "in flight" shots (bird against a light background) would be much easier with spot metering. Having said that, I can live without it and get good captures with centre-weighted metering.
Colin
Canon 400D, (1DMkIII pre-ordered), 500mm f/4 L IS, 70-210 EF, 1.4x TC, BG-E3 grip, Manfrotto 055 + Wimberley II head, Lowepro Lenstrekker 600AW backpack, Crumpler bag.
"The glass in front of the camera and the flesh and blood behind it are more important than the camera itself". :rolleyes:
GyRob
Nov 19, 2006 15:50 |  #8
Spot metering is only good if you know how to use it properly and then ajust the camera based on the spot metre reading to get the exsposure you want ,if you get it wrong it can mess up far more than say partial or CW.
Rob.
"The LensMaster Gimbal"
Ryanisme
Nov 19, 2006 20:14 |  #9
when i looked at the 30d and the xti
it relaly came down to how it felt in my hands
the 30d has some "better" features
as stated 5fps
spot meatering
but it also just felt better in my hands which is important in a camera
also, isnt the 30d made out of magnezium? or somehtin like that
and the xti is plastic based?
Canon G6-3x lense, macro lenses
Canon 30D- Canon 18-55mm kit lense~Sigma 70-300 4-5.6 APO DG Macro~Nifty-Fifty
~ Canon24-105 L4 IS ~BG-E2N Grip
grego
Nov 19, 2006 21:57 |  #10
Spot metering's importance is relative to the user. For me its highly important but i shoot in all kinds of difficult lighting. The more harsh the lighting, the more useful it is.
The 30D has slightly better higher ISO(at 800 and 1600). Also the 30D has 1/3 ISO stops, which is very nice if you are a low light shooter.
So for instance between 800 and 1600, you also have 1000 and 1250 as two extra stops. Really there's no way of evaulating this without actually handling the camera and using it for a little. At the very least, you should handle both. Even with your small hands.
No stat of experience for any individual here will really convey the actual feeling and what not. The thing that will bring on the weight is the glass, more than the body(especially if you don't use a grip).
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Nov 19, 2006 22:00 as a reply to  @ grego's post |  #11
I have only had my 30D for 2days..but I love this spot metering. I know whats going to have the exposure. It was really helpful with flowers I was shooting.
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
RichNY
Nov 20, 2006 00:53 as a reply to  @ 05Xrunner's post |  #12
Even if you never used spot metering the 30D offers a better build quality (metal v. plastic), a longer shutter life, and a more comfortable feel in your hands for most people.
You'd be surprised what a nice feature 5fps is when shooting portaits as well as sports photography when you want to get that perfect facial expression.
If you ever purchase or rent a longer/heavier lens such as the 70-200 f/2.8 you will find that the camera is better balanced with a heavier body (even nicer with a BG-E2 battery holder attached to the 30D.)
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
René ­ Damkot
Nov 20, 2006 03:44 |  #13
I think the second dial on the back makes a bigger difference. Not having that *would* be a deal breaker for me.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,617 views & 0 likes for this thread, 11 members have posted to it.
2258 guests, 125 members online
