Thread started 19 Nov 2006 (Sunday) 19:44
580EX doesn't recognize my focal length
Poe
Nov 19, 2006 19:44 |  #1
I try setting the flash zoom to the mode where the flash head zooms in and out depending on my zoom lens's focal length, but now it just reads "Zoom -- mm" and the rectangle icon on the right of "mm" that signals it has "auto-detected" my sensor size doesn't show either. If I switch to manual zoom the flash can be zoomed in and out manually. Does anyone know how to rectify this issue? I'm using the 17-40 f/4 and a Rebel XT.
Thanks!
Nikon D750, D7200 | Nikon-Nikkor 14-24G, 60G Micro, 70-300E | SIGMA 35A, 105 OS, 24-105 OS | ZEISS Distagon 2.0/25 Classic, Apo-Distagon 1.4/55 Otus, Apo-Planar 1.4/85 Otus, Makro-Planar 2/100 Classic, Apo-Sonnar 2/135 Classic
MegaTron
Joined Jun 2005
Nov 19, 2006 20:00 |  #2
Is the plastic thing (i have no idea what its called) pulled out covering the flash?
Poe
Nov 19, 2006 20:03 |  #3
no. I do pull out the bounce card, but i push the plastic wide angle diffuser back in. Perhaps i didn't put it back in all the way?
MegaTron
Joined Jun 2005
Nov 19, 2006 20:13 |  #4
I have no idea, but try pushing both the bounce card and the wide angle diffuser back in, then see if it works.
TMR ­ Design
Joined Feb 2006
Nov 19, 2006 20:24 as a reply to  @ MegaTron's post |  #5
If the flash head is not pointing straight forward it doesn't indicate the focal length. At least that is how it is with a fixed focal length lens. I'm not sure if it's the same with a zoom lens.
Robert
Poe
Nov 19, 2006 20:48 |  #6
TMR Design, you are correct. Thanks for explaining this nuance.
1,481 views & 0 likes for this thread, 3 members have posted to it.
1503 guests, 136 members online
