Thread started 19 Nov 2006 (Sunday) 20:24
DIGITAL LIGHTING
theloanexperts
Nov 19, 2006 20:24 |  #1
I am going to be using fluorescent, continuous lighting for my digital portraits. Do I need to invest in a light meter for this, or would the TTL metering work ok?
Thanks!
SkipD
Joined Dec 2002
Nov 19, 2006 20:31 |  #2
theloanexperts wrote in post #2287029 (external link)
Thanks!
Be EXTREMELY careful with using flourescent lighting. If the ballast is working at line frequency (60 Hertz in North America and 50 Hertz in a lot of the rest of the world), the intensity and color of the light will be changing at twice the line frequency and you will have a really frustrating time getting your images to look good.
Even if you find flourescent lighting that runs at a high frequency, there may not be the full spectrum of color from the lighting that you would hope for. That will cause all sorts of problems with getting true-to-life colors in your images.
As for the metering question, you can use the in-camera meter but it won't be as effective as a handheld meter that can take incident readings. Another way to emulate what an incident meter can do is to use a fairly large standard 18% gray card and a reflected-light meter. The meter in your camera would work for this, but is not nearly as convenient to use as a handheld meter. You will soon tire of taking the camera off the tripod to take readings with every change in lighting.
Skip Douglas
793 views & 0 likes for this thread, 2 members have posted to it.
DIGITAL LIGHTING
2258 guests, 125 members online
