Thread started 19 Nov 2006 (Sunday) 21:57
What's wrong with my camera?!?!
Kristina
Nov 19, 2006 21:57 |  #1
It worked fine earlier today and then when I tried to take a picture tonight this happened. It happens with and without flash. I thought it was the shutter at first (I've taken about 16,000 pictures) but I have no idea. Thanks!
Kristina
Canon EOS Digital Rebel
18-55mm, 75-300mm
my flickr (external link) photos
deadpass
Nov 19, 2006 22:00 |  #2
hmm....it definately looks like a flash sync problem, but if it's doing that without a flash firing then i'm not really sure.
a camera
http://www.deadpass.co​m (external link)
JaertX
Nov 19, 2006 22:01 |  #3
that happened without flash too? just looks like a sync issue with the shutter.
Jason - I use Canon and stuff
Kristina
Nov 19, 2006 22:04 as a reply to  @ JaertX's post |  #4
yeah, that's what I thought too so I did one without the flash. I've done long and short exposures and horizontal and vertical. They all have the same problem.
Kristina
18-55mm, 75-300mm
GeneMan88
Joined Jan 2005
Nov 19, 2006 22:11 |  #5
I wonder if this is a mirror issue... maybe the mirror isn't flipping out/all the way out of the way.
1D MKI + 1Ds MKI + 5D MKI Kit - EF17-35 f2.8L | EF24-70 f2.8 L | EF 100-400L IS | EF15 f2.8 | EF35L | EF50 f1.4 | EF85 f1.8 | EF135L | 580EX II | 580EX I | 270EX II | G12
PDX/Vancouver Photography Meetup Group (external link)
wolf
Joined Sep 2004
Nov 19, 2006 22:13 as a reply to  @ Kristina's post |  #6
Put your camera in bulb mode and trigger the shutter or active the sensor clean mode then take the lens off and see if the secondary mirror is hanging down.
<> My Gear <>
Skrim17
Nov 19, 2006 22:14 |  #7
I remember someone here who bought a used 30D having this same problem...tryign to search the thread out.
Crissa
RgB
Nov 19, 2006 22:16 |  #8
Looks like a failing shutter. But don't take my word for it.
Daniel Speranza
30D - 580EX II
Lee ND Grad Filters---77mmWide Angle Adapter
10-22mm f/3.5-4.5 USM --- 24-70mm f/2.8L USM
Website (external link) * Flickr (external link) * Gear
Kristina
Nov 19, 2006 22:41 as a reply to  @ RgB's post |  #9
ok, not sure if this is normal or not. I have it on sensor cleaning mode. It's hard to tell though with the pictures. I'm pretty sure something's wrong with this.
Kristina
18-55mm, 75-300mm
Lightstream
Yoda
Joined Feb 2006
Nov 19, 2006 22:46 |  #10
300D sub-mirror assembly failure. Call Canon.
cgratti
Lord_Malone, your still a newb...
Joined Feb 2004
Nov 19, 2006 22:50 |  #11
There is a clip that breaks in the 300D, Canon has already addressed this isseu. There is a thread on it here also.
Canon 30D
Canon 10D
Canon 28-105 f/3.5-4.5 II USM
Apple iMac G5
Kristina
Nov 19, 2006 22:50 |  #12
Thanks everyone.
Kristina
18-55mm, 75-300mm
cgratti
Joined Feb 2004
Nov 19, 2006 22:57 |  #13
lock the mirror up and take a photo.. if it takes a good picture it's probably the mirror hinge. About $200 to fix.
Canon 30D
Canon 10D
Apple iMac G5
fpiazza99
1 post
Nov 19, 2006 23:00 as a reply to  @ Kristina's post |  #14
What do you see through the viewer? Is it a full view of the subject? If so, then its most likely a mirror mechanism problem...
Kristina
Nov 19, 2006 23:03 |  #15
ok, well...i put it back on bulb and held it open and the lower mirror did not go up (like it shows in the picture) so i helped it and it gave it a push up. When I re-clicked the shutter it went up like it should and took a full picture. So far, it's still taking full frames but I'm guessing I should still call because it will probably happen again.
Kristina
18-55mm, 75-300mm
1,834 views & 0 likes for this thread, 13 members have posted to it.
2258 guests, 125 members online
