Thread started 20 Nov 2006 (Monday) 08:54
350D strange behavior
mantra
Nov 20, 2006 08:54 |  #1
Hi
I found a strange behavior of my canon 350D , every time i make a shoot with
Partial 9% at center , i found the photos more dark (lightly) under exposed
did you find the same behavior ? or is a lack of my camera
thanks
kinds regards
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
René ­ Damkot
Nov 20, 2006 08:59 |  #2
What were you metering of? Post a few images...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
mantra
Nov 20, 2006 09:07 |  #3
René Damkot wrote in post #2288802 (external link)
in every photo , for example landascape
mantra
Nov 20, 2006 09:11 as a reply to  @ mantra's post |  #4
the second
René ­ Damkot
Nov 20, 2006 09:21 |  #5
Bright tree in the middle...
I presume the second is evaluative?
Do some reading on light metering, 18% gray and the zone system. That might help understand what's happening.
mantra
Nov 20, 2006 09:53 |  #6
yes the second is evalutative
René Damkot wrote in post #2288871 (external link)
sorry i did not understand what have i to do:o :o
René ­ Damkot
Nov 20, 2006 10:47 |  #7
Do some reading up on what your camera is metering. The light meter essentially presumes the world is 'medium gray': If you take a picture of a black cat in a coalmine, the camera doesn't know it's black, so will produce a gray image. Same for a snowman in the Alps.... That's why it's important to understand what's happening, so you can tell the camera what to do.
Some reading about exposure (external link).
Some reading about the Zone System (external link)
rhys
Dis-Membered
Nov 20, 2006 10:53 |  #8
The camera meter is very stupid. You can't let the camera meter do your thinking for you. Move the lens around the scene to see what the variation in exposure will be. I usually use matrix metering (which gets it right most of the time). When you know how your meter reacts then you'll be able to control your exposures far more effectively.
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk (external link)
www.sageworld.org (external link)
www.sagephotoworld.com (external link)
Blog: http://360.yahoo.com/t​hunderintheheavens (external link)
Free cheese comes only in mousetraps
mantra
Nov 20, 2006 11:30 as a reply to  @ rhys's post |  #9
I would love if a 350D owner could do 2 shoots for me , and compare them
mantra
Nov 21, 2006 00:31 as a reply to  @ mantra's post |  #10
Tested 3 new 350Ds and every 350D i test under expose every time about 1/3
so i think it's normal for the 350
René ­ Damkot
Nov 21, 2006 02:39 |  #11
Did you all test with a lighter then medium gray tree in the middle of the VF?
My guess would be, that if a dark tree were in the middle of the VF the results might be somewhat different...
cdifoto
Don't get pissy with me
Nov 21, 2006 02:42 |  #12
"Understanding Exposure" by Bryan Peterson. Probably wouldn't hurt to have a copy.
mantra
Nov 21, 2006 04:47 as a reply to  @ cdifoto's post |  #13
i tried 4 new 350Ds in different situation , and every canon 350 in Partial 9% at center under exose about 1/3
in every situation , and every camera (the 4 new 350) gave the same results
StewartR
"your nose is too big"
Nov 21, 2006 08:41 |  #14
I think photo #1 looks about what I'd expect if it was done with partial metering on the yellow tree. The tree could well be a bit lighter than the standard 18% grey, so the camera has underexposed.
So what's the issue?
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
AdamJL
Nov 22, 2006 05:17 |  #15
mantra wrote in post #2292571 (external link)
Lucky you.. my bloody thing over-exposes by a couple of stops sometimes.
Need to get that checked out.
Gear
2,342 views & 0 likes for this thread, 8 members have posted to it.
2182 guests, 129 members online
