Thread started 21 Nov 2006 (Tuesday) 14:03
How to remove flash glare on face?
John ­ E
Nov 21, 2006 14:03 |  #1
Any advice on how to remove the camera flash glare from this man's face using Photoshop CS2? Any advice would be appreciated.
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
DaveG
Joined Aug 2003
Nov 21, 2006 14:10 |  #2
I'd star by trying the rubber stamp tool. I'd have it fairly large and would have it set to about 35% opacity. I would sample from the non glare area and clone it onto the harsh reflections. You might want to use a lower or higher opacity as each image requires a different approach, but by using something in the 35% (or lower) area you can build it up until you are satisified.
I would probably leave a little of the flash reflection as covering it up completely may look funny, but again that's and image to image decision.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
CyberPet
Hiding Under a Rock
Nov 21, 2006 17:35 |  #3
Use the clone tool, set the opacity to about 30-50% (depending on the results), use a soft brush and also set the blending mode to Darker, and it'll only affect the pixels that are brighter than the sample area (sample often though, so you dont move over a new texture or darker area).
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
3,675 views & 0 likes for this thread, 3 members have posted to it.
498 guests, 126 members online
