Thread started 23 Nov 2006 (Thursday) 03:11
Canon 10D Lens Question?
jsanz11
Nov 23, 2006 03:11 |  #1
I recently got a canon 10D body only as a backup. Now i have the 18-55mm lens that fits all my cameras except the 10D. Does anyone know what lens came with this camera? Or what lens fits it? I'd like a 18-55 for the 10D but i'm not even sure if they make it. If anyone knows please let me know.
Another question...anyone have the 10D manual for sale?
Thanks,
-Joey
Canon Equipment
1D Mark III, 1D Mark II, 5D Mark II, 30D
300 f/2.8 | 100-400 F/4.5-5.6 | 70-200 f2.8 | 24-70 f/2.8 | 85 F/1.8 | 50 f/1.4 | 1.4x & 2x Extenders | 100 F/2.8 Macro |
WWW.JSPHOTOSTUDIO.COM (external link)
PaulB
Joined Apr 2003
Nov 23, 2006 04:23 |  #2
The 10D didn't have a kit lens when it came out and as you have found the Canon 18-55mm doesn't fit.
One way round it is to modify your Canon 18-55mm to fit the 10D - see here:
http://members.cox.net …ller/EFS-WEB/EFS-WEB.html (external link).
I don't think you need to do the contour gauging bit, I didn't anyway, just a bit of judicious measuring. It does work and on a 10D the results are fine, the lens isn't ruined for EF-S bodies either, but WILL NOT fit the larger sensored bodies such as the 5D or 1 Series.
But if you do undertake the mod. then any problems can't be my responsibility!
Instruction manual in PDF - www.cleaningdigitalcam​eras.com/pdf/EOS10DIM-EN.pdf (external link)
SkipD
Joined Dec 2002
Nov 23, 2006 05:13 |  #3
All of the EF series (but NOT the EF-S) series lenses will work just fine on the 10D.
I would NOT suggest modifying EF-S lenses for the 10D, though, because some of them project far enough into the mirror box that it is possible (though not nearly as likely as on the 5D, for example) that at certain zoom settings the camera's mirror could contact the rear element of the lens.
Some EF-S lenses may work fine on the 10D when modified, but is it really worth the risk? I think not.
Skip Douglas
cdifoto
Don't get pissy with me
Nov 23, 2006 05:19 |  #4
Just get a third party crop lens instead if you really want digital only glass. They work fine because they don't have the rear protrusion as on the EF-S line. The kit lens isn't something spectacular enough to worry about compatibility anyway, IMHO.
motion_projekt
Nov 23, 2006 05:19 |  #5
When my friend bought his 10D back in the day he got it in a kit bundle type thing.
Canon EOS 10D
Canon EF 28-90mm f/4-5.6 USM
Canon EF 75-300mm f/4-5.6 III
Spare Battery
and i agree with Skip.
//Happy Shooting
EOS 5Dmk3x2 | 24L | 50L | 135L
Instagram (external link) | Gear | SportsShooter (external link) | Portfolio (external link) | Blog (external link)
John_B
Gallery: 178 photos
Nov 23, 2006 05:34 |  #6
jsanz11,
Here is a link where you can get the Canon 10D manual in PDF format (external link)
For the EF-s 18-55 lens I agree with Skip, is it really worth the risk? ???
click to see (external link)
MrChad
Joined Aug 2004
Nov 23, 2006 13:19 as a reply to  @ John_B's post |  #7
You could purchase a Sigma 18-50mm f/3.5-5.6 for 10D if need be, it's barely $100. Cheap enough.
I think the inferred kit lens for the D30/60 & 10D was the 24-85mm USM f/3.5-4.5 II lens.
I kaNt sPeL...
[Gear List]
TeeJay
Joined Jun 2005
Nov 23, 2006 13:24 |  #8
PaulB wrote in post #2302709 (external link)
One way round it is to modify your Canon 18-55mm to fit the 10D - see here:http://members.cox.net …ller/EFS-WEB/EFS-WEB.html (external link).
Good grief! after reading this I'm not convinced it's worth the EFFORT, let alone the risk! :confused:
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
dataxy.com
Nov 23, 2006 20:51 as a reply to  @ TeeJay's post |  #9
The 10d is pictured on the manual with the ef 24-85 f3.5-4.5.
dataxy.com (external link)
1,831 views & 0 likes for this thread, 9 members have posted to it.
2187 guests, 129 members online
