Thread started 23 Nov 2006 (Thursday) 04:11
Challenging color temp & skin tone.
peatoire
Joined Nov 2005
Nov 23, 2006 04:11 |  #1
when shooting indoors and col temp is around 2k, auto WB obviously gives very red/orange balance, has anyone else found that correcting the WB by shooting a white card in these conditions can wreak havoc with skin tones. I find certain parts of the skin (usually the lighter tones) turn very pink and this is very unflattering while other tonal ranges are ok. I tend to make a compromise which still leaves the image warmer than ideal.
5D & Grip, 17-40 f4, 70-200 f2.8 IS, 50mm 1.4, 85mm1.2 580EX 430EX II, Tamron SP AF 90mm f/2.8 Macro. Rickety tripod.
Andy Peat
Don't underestimate the power of stupid people in large numbers.
peatoire
Joined Nov 2005
Nov 23, 2006 04:37 |  #2
Just realised this should really be in 'Talk about Photography' sorry
Andy Peat
SkipD
Joined Dec 2002
Nov 23, 2006 05:18 |  #3
My strong suggestion - use a standard 18% gray card (one that is truly designed for the purpose) as a white balance reference. White cards can easily be overexposed when using them in a scene as a reference, while the gray card will probably not be either over- or under-exposed. That makes a huge difference when using it as a white balance reference.
Shoot in RAW and include a gray card in one test shot. Then, in the beginning of the RAW conversion process, click on the gray card with the white balance "eyedropper" tool. You will see a Kelvin value that is a result of the calculation. Transfer that number to the rest of the shots taken in the same light and do a batch RAW conversion and voila - you'll have just about the best possible white balance correction.
It is a fact that different light sources have a different color distribution in them. Not all light sources have all the colors in them. Thus, even though you do a white balance correction, all the colors in an image may not be right with some lighting sources. I am planning on doing some research into the different types of lighting sources and the color distribution in them.
Skip Douglas
peatoire
Joined Nov 2005
Nov 23, 2006 05:26 |  #4
Thanks for the reply Skip, do you know what, the thought had just popped in to my head about overexposing the white card just a few minutes ago, I'm glad you confirmed it.
I shoot RAW pretty much always, mainly to give me control over WB but I'll definitely get myself a grey card now. Interseting last point, maybe this could explain the patchiness of skin tones sometimes.
Cheers
Andy
Andy Peat
Jon
Joined Jun 2004
Nov 23, 2006 09:16 |  #5
And a colour temp. of 2000 K is pretty far down - candlelight or open flame, maybe, which may get mixed with another light source for mixed lighting headaches.
Jon
Cocker Spaniels
2,105 views & 0 likes for this thread, 3 members have posted to it.
2182 guests, 129 members online
