Thread started 24 Nov 2006 (Friday) 09:36
AF Point and ZoomBrowser
TMR ­ Design
Joined Feb 2006
Nov 24, 2006 09:36 |  #1
I'm sure there is a setting or mode that has made this change but I can't figure it out.
When I first got the 30D and installed the newer EOS version of ZoomBrowser I was able to open the image in ZB and then click on the AF Pount icon in the window and it would show me the red square for the AF point used.
Somewhere along they way this changed and now when I open the image in ZB and click the AF Point icon it shows me the 9 AF points but none are in red indicating which point was used. I'm seeing the point when I shoot but not in ZB. If I check one of those original images the AF point does show up in red.
What did I change? or what camera mode will enable or disable this? Does this have anything to do with changing C.Fn 4?
Robert
kram
obvious its pointless
Nov 24, 2006 09:43 |  #2
Cant believe I find someone post exactly the same question. I am trying to find why some of my shots are not looking so much in focus - and all I can see is 9 black spots.
I also C fn 4-1.
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
TMR ­ Design
Joined Feb 2006
Nov 24, 2006 09:48 as a reply to  @ kram's post |  #3
I'm going to try switching C.Fn 4 back to default and see what happens.
EDIT: I just changed C.Fn 4 back to 0 and sure enough, now I see AF points in ZoomBroswer. That seems to be an odd tradeoff. It's not important to see. I was more curious that anything. Makes no sense, but ok.
Robert
kram
Nov 24, 2006 09:49 |  #4
My shots in the 'idiot' mode have the red highlighted....gotto be something to do with c fn 4!!
John ­ T
Nov 24, 2006 09:49 |  #5
Hi,
I'm running version 5.7.2.18(7L) of ImageBrowser (supplied with my 30D)
After clicking on a thumbnail, on going to "view>show AF frame" all frames are shown with the active one highlighted in red - just as originally in the viewfinder.
Have you upgraded your browser from the Canon site?
TMR ­ Design
Joined Feb 2006
Nov 24, 2006 10:00 as a reply to  @ John T's post |  #6
John,
Read up to my followup post. This happens when you change C.Fn 4. In the default 0 position it works fine which explains why I saw AF points in ZB for the first week or so of owning the camera and then I discovered C.Fn 4-1 and 3 and have used my camera this way since.
Robert
John ­ T
Nov 24, 2006 14:29 |  #7
TMR Design wrote in post #2307320 (external link)
John,
Oh dear! That'll teach me to read threads more carefully before replying! :o As you say, it makes no sense!
PacAce
Joined Feb 2003
Nov 24, 2006 14:57 |  #8
TMR Design wrote in post #2307288 (external link)
It does make sense. If you don't keep the "*" button pressed when you take a shot, as far as the camera is concerned, there is no active AF point and, hence, no red AF point shows up in Zoom/Image Browser. If you have the "*" button pressed when you take the picture so that the camera will know which AF point is currently in use, you'll see the red AF box show up in Zoom/Image Browser.
...Leo
TMR ­ Design
Joined Feb 2006
Nov 24, 2006 16:50 as a reply to  @ PacAce's post |  #9
Ahhhhhh Wisdom. Thank you. That DOES make sense.
Robert
door
Joined Jun 2005
Nov 27, 2006 03:15 |  #10
What happens when you focus re-compose?
1,081 views & 0 likes for this thread, 5 members have posted to it.
1744 guests, 132 members online
