Thread started 28 Nov 2006 (Tuesday) 17:55
Adding a third studio strobe ....
F308 ­ MAN
"i'm as thick as pig sheite"
Nov 28, 2006 17:55 |  #1
I have two Bowens Gemini 500w strobes which i use (generally) with an umbrella and a soft-box.
I am looking to add a third unit for backlight or background light .... should i invest in a strobe with the same power output, or could i save some cash and buy a less powerful unit, maybe even a different manufacturer ?
I am also close to purchasing a wireless firing system, but i know very little about these units .... can anyone help with any advice, spec and cost please ?
many thanks in anticipation,
cheers,
david
Isle of Man .... "The Road Racing Capital of the World"
MaxZoom
Nov 29, 2006 01:21 |  #2
I use a two strobe system and would love to move to a three set-up too.
I guess I would go for equal power at max but with a power adjustment.
My question would be is there an economical boom available to support the third strobe? I want to do hair-lighting from directly above and behind the subject, all my stands at the moment are straight up so the #3 light has to be off to one side, out of shot.
I've just rescued a Pringles tube and will experiment with a home-made snoot with an battery powered old flash, seen some good samples of it in use, the big prob ls how to hold the flash in position.
Max :rolleyes:
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
chtgrubbs
Joined Jul 2003
Nov 29, 2006 07:42 |  #3
A third strobe can usually be of lower output. A hairlight usually is of lower power, and if you needed the 500W for a background light then you could use the smaller strobe for a fill light. But I would recommend sticking with the same brand of strobe so that the color temp of the light is consistent.
TeeJay
Joined Jun 2005
Nov 29, 2006 08:04 |  #4
chtgrubbs wrote in post #2328516 (external link)
For a heavy duty boom arm, try here: ttp://www.photodeals.c​o.uk/home.php?cat=10 (external link)
They also do a low-priced 47" octagonal box as well.
My bet is you could get the same thing on ebay, but I suppose it depends on where you live, and what the delivery costs are. I have allways found this company to be good.
As for another strobe, I would certainly recommend going for the same manufacturer, although if you only ever want to use as background/hairlight, one of lesser power should be OK - but, it's like anything else connected with this photography lark, can you never say never? :rolleyes:
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
TeeJay
Joined Jun 2005
Nov 29, 2006 08:06 |  #5
MaxZoom wrote in post #2327798 (external link)
...I've just rescued a Pringles tube and will experiment with a home-made snoot with an battery powered old flash, seen some good samples of it in use, the big prob ls how to hold the flash in position.
:D :confused:
... or, you could have a look at the low-cost hairlight cones (aka snoots) from www.studioflash.co.uk (external link) - again, I highly recommend them - and they support this forum with their advertising.
TJ
F308 ­ MAN
Nov 29, 2006 16:20 as a reply to  @ TeeJay's post |  #6
top replies .... thank you all very much ... cheers, d
1,456 views & 0 likes for this thread, 4 members have posted to it.
852 guests, 176 members online
