Thread started 29 Nov 2006 (Wednesday) 09:20
What are the best settings on a 30D?
sebmour
Nov 29, 2006 09:20 |  #1
HI, wondering what are yours ettings to get really sharp images either for portraits or sports...
Thank you new to this 30D so not use to it.
Montreal and Destination wedding photographer (external link)
5DIII, 5DII X2, 15mm f2.8, 24L,35L, 50 1.4, 85LII, 135L, 200LIS, 2X430EXII, 4X580EXII
Jon
Joined Jun 2004
Nov 29, 2006 09:21 |  #2
What looks best to one may not look best to everybody. Play around with yours until you find settings you like. I shoot in RAW and post-process based on the desired final print size, so I tend to take the defaults.
Jon
Cocker Spaniels
ScottE
Joined Oct 2004
Nov 29, 2006 10:39 |  #3
Set the AF to AI Servo. Set it to continuous shooting (3 overlapping rectangles). Set image quality on large, fine JPEG. Set the top dial on P. You can use that until you learn to how to take control your camera yourself. Enroll in a photography course to do that.
If you are shooting portraits or sports outside in the snow and your pictures look dark you may have to move exposure compensation a few notches to the right.
sebmour
Nov 29, 2006 11:20 |  #4
ScottE wrote in post #2329146 (external link)
No i already know how to shoot, been atit for 15 years....:p
But just wondering what would be the best settings to get maximum sharpness out of images!
ScottE
Joined Oct 2004
Nov 29, 2006 12:41 |  #5
Sorry, I thought you meant you were new to photography.
Getting a sharp image with digital is no different from capturing a sharp image with film. Shutter speed, aperture for depth of field, camera movement and subject movement all have the same effect.
With digital you also control sharpness by how you process the image. If you shoot JPEG, the camera has several sharpness settings you can choose for in-camera processing, so less or none has to be done on the computer. If you shoot RAW, you have complete control over sharpening in post processing.
The effect of sharpness is achieved both through enhancing contrast and actually computer processing to enhance separation of tones and colours. The procedures are similar for JPEG or RAW, but much of the RAW processing is done in the converter program while JPEG adjustments are done in Photoshop (large adjustments) or Qimage (small adjustments at time of processing). Generally the first thing I do is adjust levels. This enhances overall contrast if the left or right slider are moved in to the edge of the histogram curve. The next adjustment I make is to curves. This is used to lighten shadows, darken highlights and adjust mid tone values, but it also effects contrast and the perception of sharpness. My final stage in post processing is sharpening using "unsharp mask". You have to be careful with this because too much sharpening leads to unsightly light halos around subjects where the computer has tried to emphasize boarders too much, so only apply as much sharpening as you need for the particular image. I tend to process batches of image and the same sharpening setting can be used on similar images.
ScottE
Joined Oct 2004
Nov 29, 2006 12:44 |  #6
I should also mention that for sports, a high ISO setting is much better than using a high ISO film. You can shoot ISO 800 or 1600 with your D30 and still get a reasonably low noise image where colour film, especially slide film, would start to show objectionable grain.
Jon
Joined Jun 2004
Nov 29, 2006 12:50 |  #7
I believe he's asking about the in-camera processing parameters.
Jon
Cocker Spaniels
unix04
a title too
Nov 29, 2006 12:58 |  #8
i usually try to shoot around...
Shutter speed = 1 / 2xFocalLength (or faster)
Aperture = f/5.6~f/11 (though this really depends on whether you want background blur)
Sharpness setting = 4 (any more and it sorta makes the pic look funky IMO)
Currently:
Canon EOS 30D | 5D | EF 85mm f/1.8 USM | EF 24-105/4L IS USM | EF 70-200/2.8 IS USM | Speedlite 430EX
canoflan
Nov 29, 2006 15:44 |  #9
sebmour wrote in post #2328849 (external link)
Sharpness, assuming you have a decent shutter speed for the activity you are photographing and no camera shake etc... is affecting your shot, is mainly going to be determined by your lens. The higher end lenses will get you sharper photos. I shoot in RAW, then sharpen there and strictly use L lenses because I want all my time spent shooting to be dependent on me, not my equipment for high quality, sharp shots.
11,659 views & 0 likes for this thread, 5 members have posted to it.
2030 guests, 127 members online
